View Full Version : greddy turbo newbie questions
rx808boi
10-09-2007, 04:51 AM
ok heres my dilema......I install the greddy kit myself and it was a sucess. No leaks, No ruff idle, and vaccum/oil lines were securely tighten.
ran a test run and everything was where is was needed to be. this past weekend it ran fine also.
but now its been flooding not a whole lot but enough to make the plugs not being able to fully fire up the engine. It happened to me 3 times already with in the past12 hrs. Is it maybe because im running NGK-5255 plugs? I thought the stock plugs were too hot for the kit.
It seems to run fine when it does finally start but why is it running so rich?:banghead:
sorry for the newbie questions but I want to fix this problem asap. thanks in advance:)
Kane
10-09-2007, 06:04 AM
Could be the plugs. The colder plugs are not required, especially for low boost. I have a few thousand miles on stock plugs with the greddy at 6 PSI with no issues.
mysql101
10-09-2007, 08:11 AM
plugs aren't the issue. I'd look at the tuning
VarneyMazda
10-09-2007, 10:02 AM
ditto.. what ems are you running.
Doesnt the EMU have a cold start fuel map?
maybe thats your problem.
but im a noob.
:lol2:
tdiddy
10-09-2007, 10:08 AM
What is your AFR? Do you have an AFR gauge?
Terrance26
10-10-2007, 11:04 PM
Not that it might fix your problem, but I use to use rx-7 plugs in my 8.
