Electrical Gauge(s) - Grounding Sending Units
Old Oct 8, 2007 | 09:23 PM
elf's Avatar
elf
What pointy ears?
Here's some pics of some grounding locations that you can use for the sending units for electrical gauges (e.g., oil & water temp, oil pressure). Teflon tape was used to seal the units to the Racing Beat sensor adaptors so small hose clamps were used to attach the grounding wires to the sensors, as can be seen in the pictures.
Please excuse the dirty engine bay ... didn't get a chance to clean it before the pics were taken.
Requirements:
* Exacto knife
* Being a contortionist and double-jointed helps a lot working underneath the dash and steering wheel
Water temp sending unit:
Body of sending unit grounded with hose clamp and wire to the chassis
Oil pressure and temperature sending unit:
Body of the oil pressure sending unit grounded with a larger hose clamp and wire; body of the oil temperature sending unit can be seen above (behind) and to the right of the large oil pressure sending unit. It was grounded the same way as the water temp sending unit. Just a side note: it's best to connect and tighten ALL the sending units and wires to the RB oil adapter before you install the adapter --- you won't have very much room to turn wrenches down there once it's installed.
Both the grounding wires of the oil pressure and temp sending units were attached here (near the brake master cylinder and hood hinge area)
Routing wires from the cabin to the engine bay:
Access to the engine bay can be made through the large rubber grommet just above and to the right of the clutch pedal. This grommet already supplies a large bundle of wires to the engine bay, but by cutting a slit in the grommet, in the trough surrounding the existing wire bundle, you can push your wires through to the engine bay. They'll exit just below the master brake cylinder.
Rubber grommet is just behind the brake pedal in this picture
Close-up of the grommet. Note that there's kind of a rubber flap that straddles and covers the large wire bundle --- this can be lifted up and out of the way for better access to the grommet. You can see the wires (six 18-gauge wires and two larger black wires for the Tein EDFC) that I fed through just inside the rubber-like flap that covers the grommet. I used the Exacto knife to cut a 0.5 inch (approx.) slit in the trough for the wires. I tried resealing that section with silicone sealant, but it got a little messy (and probably not necessary anyway).
Old Oct 8, 2007 | 10:03 PM
awesome thread Elf!
Did you click on the image button and past the 'direct link' from your photobucket account?
that definitely looks like a good place to run the wires from the bay to the cabin. I guess there really is no reason to go down into the transmission with Electrical guagues. Nicely done!
Old Oct 8, 2007 | 10:33 PM
Thanks, this is excellant.
Old Oct 9, 2007 | 01:28 PM
bump for a very informational thread.
Old Oct 10, 2007 | 05:59 AM
elf's Avatar
elf
What pointy ears?
Thanx Razz and Jedi ....
Linked pics don't seem to display in the DIY section like in the other forums on this site ... and I like somewhat large pics, so I don't normally use the Attach Files for pics ... oh well.
Old Feb 23, 2008 | 09:53 AM
ChattyRX8's Avatar
Now turbo!
Is teflon tape used to also seal the senders for oil temp and oil pressure? Thanks for a great DIY!
Old Feb 23, 2008 | 04:08 PM
elf's Avatar
elf
What pointy ears?
Yup, I used the tape on all the senders --- wanted to reduce the chance of any coolant/oil leaks.
Evan Gray
Nov 24, 2015 01:00 AM
ShellDude
Oct 1, 2015 09:55 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Stubbs
Sep 27, 2015 04:06 PM
