derekfc
10-08-2007, 06:14 PM
im a member of the rx7club forum and have a first gen and second gen turbo. ive rebuilt motors and worked on the 7's quite a bit. my friend called me today looking for help on his 8 and im not sure about a few things.
symptoms.. not starting
he thought it was the sparkplugs so he replaced them.. all with trailing plugs.. not good but should still run. he didnt remember the plug wire order so i wired them like this coil pack farthest from fire wall is L1 next is T1 then L2 then T2. is that right? also he says he just filled the tank friday but the gauge shows empty with the light on. i verified spark and i deflooded it by pulling the lower plugs and fuel fuse. the plugs were dripping with fuel and starting fluid. i got it to sputter and start once where it revved up to about 2500rpm then died. i had my foot to the floor when it did this as well. do these cars have the fuel cut with a wot while starting? we also reset the computer by unplugging the battery and holding the brake pedal to the floor for about a minute.
this car is an automatic and he seems to be having a lot of problems with it. they say it runs like hell and the auto is shot
any suggestions or help would be great and ill try to find more info out. he was not sure about the fuel gauge being accurate. he said it was getting stuck at about 1/2 all the time.. related?
