Temperature nob f'd up! help!
Temperature *** f'd up! help!
ok so here's what happens...regardless of inside/outsie air or ac on/off...doesn't matter...every now and then when i turn on some air, it will blow out hot air...when i screw around with the temp *** for a little bit it will kick the AC back on...any ideas? seriously sucks when i'm tryin to have the air on and it starts blowin hot *** friggin air!
hey man i don't wan't to buy anything i don't need yet...i'll let you know...
so i saw the tsb about it going cool-warm-cool kinda uncontrollably...i think thats why my deal is...but i have 63000 miles...will they still warrenty it since it's a known issue or not? its says its only like .2 hours worth of work
had the dealer fix the hotAC as well on mine, but they will only do it until i hit 50K miles or april 08. Dont think i will put 20K more miles on my cer before then. But they said they wont fix stuff like this after the warranty is up, so you might be out of luck.
The whole control itself is couple hundred dollars.
and your warranty is *way* over. so .... they will not replace it for free.
You can buy it and replace it yourself. its not that diffcult
tommy26Germany
Sep 29, 2015 10:33 AM
