DIY request: pulley help!
Old Sep 25, 2007 | 08:11 PM
KRrotary's Avatar
i just got a set of power pulleys and i cant figure out how to get the alternator pulley to stop turning so that i can take the nut off and i dont want to break anything...anyone know how?
Old Sep 25, 2007 | 08:17 PM
mysql101's Avatar
hehe.
I had the same problem:
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/wanted-secret-alternator-pulley-removal-121978/
Old Sep 25, 2007 | 08:18 PM
1stgen8's Avatar
There are plenty threads on here that will solve your problem....use your search box. From what I've read most have used an impact wrench.
Old Sep 27, 2007 | 01:46 PM
KRrotary's Avatar
sorry, i couldnt find a thread before. thanks for the help though
Old Sep 27, 2007 | 02:13 PM
HCTR154's Avatar
Impact wrench will do the trick.
Old Nov 25, 2007 | 06:26 PM
chetrickerman's Avatar
gotta revive this thread, but what are the size of the bolts on the waterpump pulley, the nut on the alternator pulley, and the crank pully? i bought the unorthodox pulley set and i am gonna need to know this. thanks
Old Nov 25, 2007 | 06:35 PM
bump? im gonna go buy the impact wrench and sockets now, so if i need any special ones, im gonna buy them
Old Nov 25, 2007 | 06:36 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
If nobody else answers you by then, I look tomorrow and find out. It's been toolong ago. Do yourself a favor and go to WallyMart or somewhere and buy an impact wrench. You'll need it for the alternator. Mine was $29.00
Also, go to the unorthodoxracing.com website and you can download the instructions.......jus go through the motions and find out what part you have, which should be the UltraSS. The instruction may be written for the RX-7, but they are the same.
Old Nov 25, 2007 | 06:38 PM
thats what im gonna go do, but i just wanted to know if i needed to buy any special sockets. i checked out the alternator pulley nut, and that one looks to be a 15/16's.
Old Nov 25, 2007 | 06:39 PM
Mazurfer's Avatar
Get the set that runs from about 10mm to 21 or 22mm and you'll be covered for the pullies. I honestly can't remember if I used the one that came with the impact wrench for the alternator or whether I had to go buy a 24mm for that.
Old Nov 25, 2007 | 06:42 PM
Mazurfer's Avatar
Believe that works out to 24mm.....which is what I remember.
Old Nov 25, 2007 | 06:43 PM
so they are all metric? i tried 10 mm on the waterpump pulley and it didnt seem to fit. but that could just be cause its dark. thanks a lot
Old Nov 25, 2007 | 06:45 PM
Rx8urZ's Avatar
i would think it would be a metric size??? make sure its the right size last thing you want is to strip the nut
Old Nov 25, 2007 | 06:46 PM
Mazurfer's Avatar
so they are all metric? and the alternator nut is 24? i tried 10 mm on the waterpump pulley and it didnt seem to fit. but that could just be cause its dark
The whole damn car is metric. You should get a set. The smallest I've found on the car is 7mm and the largest for all purposes but the alternator was about 21mm. Had to buy a seperate socket at 24mm rather than part of a set.
You want me to go check all of them for sure right now?
Old Nov 25, 2007 | 06:48 PM
if you really want. otherwise i will just buy the set
Old Nov 25, 2007 | 06:50 PM
Mazurfer's Avatar
By the set, you'll need it.
If it doesn't come with a 24mm.......buy that one seperately. I'll go check that real quick, but you really should have a set.
Look back here in 5 minutes.
Old Nov 25, 2007 | 06:51 PM
alright thanks
Old Nov 25, 2007 | 06:54 PM
Mazurfer's Avatar
Confirmed
Alt = 24mm
All others for the Unortho set are 10mm
Just went out and checked.
Old Nov 25, 2007 | 07:03 PM
thanks a lot. im off to wally world
Old Nov 25, 2007 | 07:08 PM
Mazurfer's Avatar
Don't be surprised if you can't find the 24mm without buying the bigger set. I chose not to and went to Autozone and just got that one as I had three other metric sets.
Oh....and read that DYI carefully. When you do pull off the crank pully, there is a plate that may try to come off with it. Either don't let it come off or make real sure you know the position of that plate. It's keyed, but it's much better if you just not let it move from the position it's in. If it does come off, make damn sure it's back on correctly.
Old Nov 25, 2007 | 08:00 PM
k, will do. i got a 1/2 socket set with 9-24mm sockets . and i got the same exact impact as mysql so im set. i just need to get the pulleys now. good thing i have off this whole week.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
yankeepicker
Sep 11, 2015 05:42 PM
