AT Disappearing LED Display
Old Sep 19, 2007 | 08:32 PM
cruhigger's Avatar
After almost a month at the body shop (due to a damaged rear fender) I got the following...
My '8 does not show current gear at panel while it is stopped. After releasing the breaks the LED display will lit and show current gear (4AT) whenever I lightly step on the breaks again, the LED display will blink. If I stop the car, the LED display will turn off and even remain unlit. While the display is unlit, the car seems to stay in 2nd shift (no shifting)....
any Ideas??
Old Sep 19, 2007 | 08:49 PM
tajabaho1's Avatar
Destroying Threads
swoope come correct me if I'm wrong, but could it be a dying battery?
Old Sep 19, 2007 | 10:32 PM
yep,
you are wrong.. connector in the panel likely. not really repairable.. hope you have warranty..
Old Sep 20, 2007 | 10:07 PM
tajabaho1's Avatar
Destroying Threads
fine, I'm wrong again =.=
Old Sep 21, 2007 | 07:45 PM
cruhigger's Avatar
Thumbs up
Thanks to you both!
I made an appointment at the dealer for this tuesday. I will let you know what they find. My '8 still in warranty.
~]V[ickey~
Old Sep 25, 2007 | 10:10 PM
cruhigger's Avatar
Preliminar diagnosis
Day 1 @dealer...
They hook'd the computer to the car, systems and trans are ok. Technician suspects electrical failure at the stop lights wiring.
...remember I told you about the body shop? Current theory is that the body shop screwed the wiring when putting back the stop lights.
Day 2 @dealer
Technician is sure there is an electrical failure, has the tech drawings but cannot locate faulty cable/connection. Will call reinforcements from another dealer for tomorrow.
Day 3 @dealer
Second technician finds the culprit. Bad wiring resulting from the body shop work done. Argh! Not covered by warranty. And the car will not be ready until next day. Argh!
Shankapotamus3
Mar 14, 2021 03:53 PM
nadodave
Aug 28, 2019 05:55 AM
vapor2
Jul 9, 2016 07:35 AM
RX8mzda
Oct 14, 2015 05:12 PM
