HKS Twin Power Ignition Amplifier vs hotter sparkplugs
Old Sep 17, 2007 | 08:54 PM
sosonic's Avatar
For a NA RX-8, I was wondering if anybody had the HKS Twin Power Ignition Amplifier and thought it worked?
I also was wondering what people think about going to a hotter spark plug vs getting the HKS Twin Power Ignition Amplifier? I took my spark plugs out and after looking at them, I think I could go a little hotter. However, I'm just wondering what others think about this issue.
Ref:
http://www.rx7store.net/HKS_Twin_Pow...wer%20rx-8.htm (HKS Twin Power)
http://www.ngksparkplugs.com/techinf...300&country=US (NGK spark plugs FAQ)
http://www.dansmc.com/sparkplugs1.htm (sparkplug info. color ranges)
Old Sep 17, 2007 | 09:00 PM
tajabaho1's Avatar
Destroying Threads
I think in the other thread someone mentioned upgrading the coils>hks twin power
Old Sep 18, 2007 | 07:35 PM
Mazda has a 1-step *hotter* plug. but you can only get them thru a Mazda dealer.
N3Y9-18-110/000018N3Y9 , which is NGK RE6C-L, about 36 bucks from our forum vendor.
RE7C-L is what most stock engine comes with, you can get it anywhere online for about 20 bucks
Old Sep 19, 2007 | 03:23 AM
Fanman's Avatar
I have it on my car. Makes idle a little smoother, acceleration a bit smoother as well. No noticeable added power, but even if it gave a few hp, no way it would be measureable. I know Okada makes an upgraded coil, but a set is somewhere in the range of $700, and the only vendor I know that sells it is Vivid, so god knows when/if you would actually get them.
Why would you want to go with hotter plugs ? Wouldn't you increase your chance of detonation with this engine ?
Old Sep 19, 2007 | 05:32 AM
sosonic's Avatar
As a general rule, hotter plugs can lead to detonation. However, it depends on the car and the condition of your spark plugs. You can go hotter, if the spark plugs show you can and it all depends on the car.
Oddly, NGK seems to endorse using an ignition amplifier in certain cases. I'm trying to weigh the pros and cons.
Those Okada coils are ridiculously expensive and I don't see the gain over stock coils, unless you are racing and going all out by upgrading any parts that you can. I think many people would be better off replacing the stock coils when they replace their spark plugs.
Old Sep 19, 2007 | 07:19 AM
DMRH's Avatar
Purchased one recently.
Have an 03-model with 4AT
Will report on cars improvements when i get time to install it.
Have the hotter plugs too. Wife just putt putt putt's around all day & the hotter plug resists fouling more. I jump into it on weekends & clean it out if you know what i mean...........
REgards
Old Sep 19, 2007 | 10:14 AM
tajabaho1's Avatar
Destroying Threads
^ dont hit anythig yet!
Old Sep 19, 2007 | 06:48 PM
Fanman's Avatar
What's the point of a hotter plug ? Other than to reduce fouling & maybe a few hp ? It's just not worth the risk that you maybe putting on your car. Especially this car, where some people have had detonation issues even with regular tune. Better off getting other performance equipment.
gwailo
May 14, 2024 06:57 AM
Cookingislife1226
Mar 20, 2016 09:51 AM
TeslaMSI
Dec 10, 2015 01:10 AM
ed0128
Sep 9, 2015 04:50 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
