New rotors/pads, weird rotor wear..
Old Sep 17, 2007 | 07:40 PM
nt5k's Avatar
Question New rotors/pads, weird rotor wear..
Replaced the front rotors/pads the other weekend. (centric rotors/hawk hps pads)
Here is what they look like so far:
http://picasaweb.google.com/nezro500...ey=xdaU5865WxU
The first 2 are the rights, the last 2 are the lefts.
Not sure if it's noticeable but the left seems to be wearing a lot more evenly then the rights. I am also getting a notable drag on the right at initial movement of the car.
No vibrations/pulling to either side. Stops are pretty good and consistent.
Is this normal? Should it even out with some more miles? (only got 150 so far)
Old Sep 17, 2007 | 09:28 PM
Marc_GS's Avatar
Hooked on go-fast crack
From the looks of the rotors, the bedding in process is not done. Did you do the break-in as recommended by Hawk? IIRC, properly bedded rotors with Hawk pads are a lot darker than what is shown on your pics.
Old Sep 17, 2007 | 11:53 PM
DOMINION's Avatar
I don't buy Kool-Aid
^What he said, But it also looks like a pad is not getting full contack. Who did the job?
Old Sep 18, 2007 | 02:09 PM
nt5k's Avatar
I did the procedure that was on the hawk instructions. But will be doing it again.
I did the job. Any idea why the pad wouldn't make full contact?
Old Sep 19, 2007 | 12:14 AM
nt5k's Avatar
Ok just a followup. Things are starting to improve, I think when did the initial bedding i was a little too nice. I am now seeing the 'darker' color and the 'untouched' ring on the right side is getting smaller. couple more sessions and i'm hoping everything will even out. The drag I was feeling is also gone at this point.
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Quiggs321
Sep 30, 2015 05:34 PM
