2004 RX-8 Wont start
Old Sep 16, 2007 | 07:11 PM
Elimin8er's Avatar
My car wont start no clue as to why i just parked it.Nothing different than usual.It turns over cuntinious but nothing.Help.........
Old Sep 16, 2007 | 07:44 PM
Flood ?
and Do a Search next time would you ?
Old Sep 17, 2007 | 05:45 PM
Hold the throttle wide open. Crank the wait. keep foot to floor. Then crank again.
Use same procedure over and over. It should start. If no charge battery and do again.
If you can't do it this way you have to do the unflood procedure.
Of course if you drive around town alot and have 20k on the plugs, ignore the procedure above.
Go straight to plug replacement.
Old Sep 17, 2007 | 09:13 PM
savedsol's Avatar
Carbonormous
Have you had the updated starter? Does this happen more often when the engine is warm? If so and you don't have it go get the new starter. Happened to me. Starter solved the issue for two months until my engine crapped out for good.
Old Sep 17, 2007 | 09:52 PM
1fine8's Avatar
Its either not getting gas or has got too much gas.
Its not parked on a slant with low gas is it?
Old Sep 18, 2007 | 09:25 PM
Elimin8er's Avatar
Thanks Everyone once i found out it was flooded i just pulled my fuel fuses and cranked it over a bunch then put them back in.Worked great....
Old Sep 18, 2007 | 09:35 PM
zenmoused's Avatar
the stig is my hero
rx8club to the rescue again!
Seriously elimin8er, unless you're stranded on the side of the highway and using your iPhone to ask for help, use the search button. There are countless threads about this.
Old Sep 19, 2007 | 03:58 AM
Originally Posted by Elimin8er
cuntinious
OMG, he used the C word
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
Mr.Durden
Aug 12, 2015 02:21 PM
Rx808BI
Aug 9, 2015 10:06 AM
