Oil change through the dipstick tube using a pump?
Old Sep 14, 2007 | 02:27 PM
Tamas's Avatar
Registered Lunatic
The other day I was bored on my commute flight and flipped through the pages of the SkyMall magazine. I saw an 'oil extractor' pump that allow changing the oil without raising the car, through the dipstick tube. Then I searched a bit on the net, and found some similar devices:
http://www.go2marine.com/product.do?no=161678F
http://www.liquidvac.com/
I was wondering: did anyone use such a thing? Does it work OK? It certainly seems to be an easy and non-messy way to do oil changes. Just not sure how effective it is and how much sludge would be pumped out, seeing that it sucks the oil out from above. On the plus side, maybe it's capable of pumping out the oil from the oil coolers which a regular oil drain method doesn't do?
Old Sep 14, 2007 | 02:40 PM
mysql101's Avatar
Order one of these instead:
http://www.quickoildrainvalve.com/
It'll let you drain your oil with the flick of a lever. Since it drains from the bottom, sediments and stuff all drain out. If you suck up the fluids from the top, you aren't going to clean it out as well. Both methods will get out similar amount of oil - though you can jack up each side of the car to push out a little more oil from the coolers.
Old Sep 14, 2007 | 03:06 PM
kennyfrc1's Avatar
I am using a fliud extractor for mine. I change my oil every 1000 miles and filter every 3k. It is so easy with the extractor I just change it more often and dont worry about sediment. I will pull the drain plug every 10-15k.
Old Sep 14, 2007 | 03:15 PM
ZoomZoomH's Avatar
Mulligan User
from the homepage:
"Formally known as Fumotovalve.com"
I think they meant 'Formerly'
Engrish at its best, hehe
oh, and i do have this drain valve, 63k miles later still performing flawlessly
Old Sep 14, 2007 | 03:20 PM
alnielsen's Avatar
There has been a thread on this in the past. Your not a nube, Search.
This process is used a lot in the boating industry.
Old Sep 14, 2007 | 03:42 PM
kersh4w's Avatar
Hit & Run Magnet
he wasnt just simply asking a question, he was sharing information.
i know at least 1 dealership that does oil changes this way...
Old Sep 15, 2007 | 08:36 AM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
The he should have added it to the other thread rather than start a new one.
Which dealership? So everyone knows to avoid it.
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
RotaryRider
Jul 20, 2015 07:05 AM
