Tap ignition from trunk?
Old Sep 10, 2007 | 11:05 AM
PatInTheHat's Avatar
Anyone know if theres somewhere in the trunk you can tap ignition?
Old Sep 10, 2007 | 11:55 AM
WikkedOne's Avatar
Deals on wheels
why? are you putting another engine back there? that would be sweet!
I'm going go way out on a limb and assume you mean an accessory line to turn on your amp. use the rear cig ligter in the center console - oh and next time.. look at the sticky at the top of the forum about car audio stuff - it has way more info than you will ever need.
Old Sep 10, 2007 | 01:29 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Use the rear cig lighter in the center console.
Old Sep 11, 2007 | 11:02 AM
kimota's Avatar
Heya Pat,
I know your in the process of installing a CarPC and if I remember right your using the 2140 to power it. Your not planning on tapping some where in the trunk I.E the rear cigarette lighter to power the 2140? If thats the case I suggest you run a fused power cable from your battery to the trunk. But if you looking for remote turn on for amp the rear cigarette lighter is the way to go.
P.S
If your looking for a place to tap for pulse start with the 2140 use either of the rear signal lights.
Second P.S
Hey Rotary Rasp sorry about that condensation rant a few weeks ago
Old Sep 12, 2007 | 12:43 AM
It's for a Carnetix P1900. I'm running power/ground from the battery but I need to tap Ignition somewhere. I guess when it says it needs an ignition tap that ACC would be fine as well?
Old Sep 12, 2007 | 07:24 AM
Just use the Center console Power Plug.
Old Sep 12, 2007 | 10:09 AM
kimota's Avatar
What he said
cliffkemp
Dec 24, 2024 10:48 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
GK1707
Sep 27, 2015 07:33 PM
drlubell
Sep 26, 2015 11:58 PM
Rote8
Sep 22, 2015 03:43 PM
