Soft Grind
Old Sep 7, 2007 | 08:20 PM
refugeefrompistons's Avatar
Soft Grind
When I pull out of my driveway and start driving down the street, some times when i try to pull my shifter out of 1st or 3rd gear, i can't pull it out and i hear a chattering sound. This has happened on multiple occasions with my left foot firmly to the ground with the clutch.
Any one share similar experience or have a solution?
Old Sep 8, 2007 | 12:08 AM
what year and how many miles??
here is a start..
http://www.finishlineperformance.com...4-06-1641a.pdf
Old Sep 8, 2007 | 05:59 AM
not a clutch that is hard to disengage but thanks for the help swoope. Its a 2007 with 4k miles.
Old Sep 8, 2007 | 11:21 AM
Icemark's Avatar
They stopped having the hard to disengage problem back in May 06... so that pretty much rules out your car for the TSB problem
Old Sep 8, 2007 | 11:39 AM
Rootski's Avatar
DGAF
Does it happen as you shift gears, or does it start once you car is in neutral? Gear chatter in neutral is normal, but only with the clutch out...
Old Sep 8, 2007 | 12:22 PM
it happens as i pull it out of gear.
Old Sep 8, 2007 | 02:04 PM
kersh4w's Avatar
Hit & Run Magnet
thats happened to me to. thanks, i didnt know there was a TSB for it.
theblinkof
Oct 4, 2023 05:24 PM
Dokuji
Nov 1, 2016 02:51 PM
thewatcher101
Sep 18, 2015 01:48 PM
mitchrx8
Sep 13, 2015 08:05 AM
airlive
Sep 7, 2015 08:32 PM
