alingnment question
Old Sep 7, 2007 | 06:03 PM
kpex76's Avatar
alingnment question
what is the maximum camber front and rear the rx8 can give on a stock set-up?
I drive fairly aggressive and I would like a bit more turn in.
What are some of the alignment specs some of you semi-aggressive drivers use?
Old Sep 7, 2007 | 06:41 PM
costello's Avatar
This was my autocross setup. I was able to max out the front at -1.2 degrees. Set the back at -1.1 degrees although I think it'll go to at least -1.4 and maybe even more. I wanted it to rotate better so I used less camber in the back. Toe it out in the front a little (1/32 or 1/16) and zero the toe in the back should also help it turn in better.
Old Sep 7, 2007 | 06:49 PM
lots of good info here.
https://www.rx8club.com/rx-8-racing-25/alignment-settings-street-track-use-43308/
keep reading the whole thread. have fun..
Old Sep 8, 2007 | 12:39 AM
kpex76's Avatar
thanks guys.
excellent reading materials.
Old Sep 8, 2007 | 12:36 PM
it depends on several factors, we've been able to get over 2 deg on RF and a little less on the LF ...
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
