dual batteries?
Old Sep 7, 2007 | 10:04 AM
silverwolf's Avatar
dual batteries?
I want to hook up 2 batteries. I do not have an RX8 ( i wish...) i do have a jeep. a jeep with quiet a bit of audio that needs to be packed in it. I have 2 600 watt amps. 1 for 2 12 inch subs. and 1 for my speakers. i am running the subs with now but it manages to drain alot o' energy. I want to do a dual battery setup but i want to know if i have to have an isolator.
or can i just hook up a 2 or 4 guage wire to both positive connections and ground my neg on my other battery. i would have thought that it would charge your battery and use it just like if you would jump a car.
no?
thanks for all the help.
Old Sep 7, 2007 | 11:22 AM
WikkedOne's Avatar
Deals on wheels
I personally believe, you'd be a lot better off with, such as, one good optima yellow top or red top battery for US Americans in South Africa, instead of rigging up a second cheapy..
Also your system shouldn't be pulling that much power.. what problems are you seeing? I think your battery may just be going bad.. even more reason to change to an Optima
Old Sep 7, 2007 | 07:27 PM
DDJFLW's Avatar
buy a high output alternator
Old Sep 8, 2007 | 06:40 AM
Im wondering, whats the stock alternator rate.
Old Sep 10, 2007 | 07:37 AM
silverwolf's Avatar
not sure on that. what i do know is that i installed my subs and that now i have problems with my elecetrical
1. cant run ac on full at all i can run half power but only when i am running a gear. Its a manual.
2. by interior lights not come on when i flip my switch.
however i have no dimming on my head lights so its a little bit confusing.
there really should be no reason for those problems with out the dimming i feel. any suggestions?
also. blue top or yellow top? 2 600 watt amps.
Old Sep 10, 2007 | 11:02 AM
DDJFLW's Avatar
Sounds like a bad battery with dead cells...shouldnt do that at all unless you have volume pounding constantly. Get your alternator and battery checked. Also make sure the battery terminals are fine. I had to replace mine because of poor contact.
Old Sep 12, 2007 | 06:49 AM
silverwolf's Avatar
new battery new alternator. connections are fine no corrosion.
i have fine power in there. like i said no dimming lights. it just seems as though now randomly some things dont work till i get up to the right RPM. think ill try the new battery idea.
Blue looks higher capacity. but you always here about the yellow. choices....
anyone?
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
