Need Help Urgently !!!
Old Aug 23, 2007 | 09:54 PM
kent_sg's Avatar
My ride is under going through the fc3s swap into rx8 but i can't have the elecctronics working in it as the stock meters like the rev and speed can't read into the fc3s engine and the (Rx-8) alternator can't start.my rx 8 power steering which is electronically controlled can't be used by fc3s which is belt controlled please advice on the solution.
Old Aug 23, 2007 | 10:02 PM
Easy_E1's Avatar
I don't have an answer, but I have a question.
Why didn't research this swap before undertaking it?
Old Aug 23, 2007 | 10:05 PM
kent_sg's Avatar
there are example of sucessfull swap thinking it will be just a few adjustment of the stock items as the engine remains rotory.I must be naive to think that way as I'm facing the problems now please do help on the problems I have now,thanks.
Old Aug 23, 2007 | 10:45 PM
JB_Rotary's Avatar
Always lurking
Get a stand alone EMS. Ditch the powersteering from the FC engine and wire electric power steering into the EMS so it turns on with the car. Build a custom dash and use the EMS to run your new gauges.
........but seriously how could have not researched this and why the Fc engine over the Fd engine?
Old Aug 23, 2007 | 11:15 PM
lennon's Avatar
This is scary!!!! Bring back to where belongs.
Kent, better do more research nexttime. Transplant was never just plug-n-play.
Old Aug 23, 2007 | 11:29 PM
kent_sg's Avatar
I realise my mistake so please feed me with more info on solving the problems,bros.
Old Aug 23, 2007 | 11:36 PM
kent_sg's Avatar
Now the problems lies in the wiring from the ems to the FC3S,please advice
Old Aug 23, 2007 | 11:54 PM
rotorocks's Avatar
RotoRocks Powered
Dude, Are you friggin out of your mind? Doing the work like that without knowing what you are going to use for your EMS, and how you are going to thigh the rest of it in? This just doesn't make sense!
You are undertaking a thousands of $$ worth of a project and not thinking about basics? I don't think you are for real here bro...
No offence. Unless you have proven otherwise, I'll have no choice but to call tread BULLSHIT.
Old Aug 24, 2007 | 12:43 AM
kent_sg's Avatar
Sorry to **** you bro if that's gonna help.........Now this so called project is on and in the rx8 club there are success cases of the swap mentioned by my other bros in there but i couldn't find those guys who did it.
Old Aug 24, 2007 | 05:49 AM
rotorocks's Avatar
RotoRocks Powered
Oh you did't **** me off.
Keep searching. Ask Rogonza what the guys in PR do?
Old Aug 24, 2007 | 08:08 AM
MazsportScott's Avatar
Mazsport.net
I can build a plug and play Interceptor-X that will solve your problems. Let me know the injector sizes and I will install a base map as well.1-800-538-9989
BTW this is also available for FD engine swaps,Scott
Old Aug 24, 2007 | 09:48 AM
CnnmnSchnpps's Avatar
No means yes
Out of curiosity which engine from the FC? S4? S5? Turbo model I hope?
BTW, "FC3S" is the chassis code, so unless you are creating some sort of chimera monstrosity, what you are actually transplanting is the engine. Which would be a 13B or a 13BT.
Also, unless you are doing some porting and/or turbo upgrade, you are losing power with this swap. And you are putting a 20y/o engine in a new car... You are asking questions which should have been researched before even considering a swap, but it sounds like you have the engine half-way into the car and are typing with the other hand asking why it won't fit... I'm with rotorocks on this one...
On the other hand, if you are indeed for real, and realize the amount of money this project will most likely take... While you have the car apart anyway, how about doing some serious work on it? I did alot of research on the FC a couple years back so if you want I can dig up lots of links for how to make the 13B faster. IIRC, something like 400+ hp is achievable without too many surprises. You need turbo, fuel, and EMU
Scott, the Int-X works on the 13B ECU? Cool...
Old Aug 24, 2007 | 10:30 AM
JB_Rotary's Avatar
Always lurking
Listen to the MazsportScott. If everything else is physically in place an EMS is all that you need. Do you have pics of this setup? and why the FC engine over the FD one?
Old Aug 25, 2007 | 12:59 AM
angeljoelv's Avatar
angeljoelv
Ask RGonza, Im sure he knows what you need. He has done a couple of swaps. I did my 20b swap myself and everytime I had problem He helped me out. Most of the time over the phone, becouse he is in Puerto Rico.
Old Aug 25, 2007 | 06:50 AM
this is going to end up bad.
Old Aug 25, 2007 | 06:57 AM
DrewMan's Avatar
Culpam Poena Premit Comes
any pics?
theboy
May 24, 2007 03:33 AM
titaniumgrey
NE RX-8 Forum
Jun 12, 2004 09:59 AM
