Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
rough idle, car sometimes dies when let off thottle
Old Aug 23, 2007 | 02:44 AM
rowteree's Avatar
i was encouraged by legendkurado to post my issue in the gulf forum cause i might get more responses, but here i go.
my car is an 04 mt with 50k miles on it
it needs:
-tranny fluid swap
-rear differential swap
-oil change soon
-squeeky clutch need to be taken care of
-my undertray has been completely torn off, so it can possibly be diverting the air back towards the ground instead of towards the radiator and the MAF tube
-and other minor things
my problem is that my car sometimes has a rough idle and then sometimes shuts off. I know its not the battery cause the minute it shuts off, im able to start it up again. At a stand still it doesnt shut off, but while on a roll the idle drops to zero and shuts off, there i have to start it up again and sometimes i have to apply pressure to the gas pedal keeping it from shutting off. I did the 20 brake tap thing and the problem seemed to go away and ran strong and fine, but with an iffy idle
mods i have:
ground wire
throttle body bypass
ac colder mod
bb exhaust
and AP pulley that has yet to be installed
what is going on?
my spark plugs were changed at 30k miles
do i possibly need new:
coils?
plugs?
ignition wires?
check my MAF?
check intake position?
tomorrow im removing my intake to check if it was positioned right or incorrectly installed. Please anyone have any knowledge on this?
Old Aug 23, 2007 | 07:38 AM
RXH8TED's Avatar
PoOn
check your cat. If its clogged it will stop your car from running...And if its only partialy clogged then it could only be a problem when your driving and not when sitting still. What kind of intake you got? I personally doubt its the intake, seeing as the intake gets air from the front of the car not underneeth.
Old Aug 23, 2007 | 02:29 PM
rowteree's Avatar
stock intake
Old Aug 23, 2007 | 04:26 PM
RPM666's Avatar
I want a turbo
Could probably scratch MAF/Intake off the list unless the actual intake tube is damaged or sensor is loose/out of position and there's no CEL. What in the world did you run over to tear off the undertray?
Old Aug 23, 2007 | 05:36 PM
Ajax's Avatar
fouled plugs and or bad coils..
Old Aug 23, 2007 | 07:01 PM
rowteree's Avatar
I rechecked the MAF sensor and it's on, but it was sort of loose. Checked how my intake was positioned and tightened my ground wire kit. My under tray has been tearing off ever since i put on my m-speed bumper and the tropical storm that happen a week ago in houston just completely tore off the rest.
ill check my coils and plugs at the dealer
Quato_jr
Aug 4, 2015 09:22 AM
marc2820
Jul 26, 2015 10:47 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
netrovers
Jul 20, 2015 03:32 AM
