CEL, need help deciphering codes
Old Aug 20, 2007 | 10:17 AM
genjuromikos's Avatar
i just recently installed the mazdaspeed cai now i been getting a check engine light when i start up the car , dont know if it's coming on because of that though.
i hooked up my scanner to the obd and got dtc codes, U0155 and P0610, i looked in the sticky thread at all the dtc codes, but i still don't know what they mean in noobie terms, are these codes cause for any concerns, what do they mean and how do i fix them...
Old Aug 20, 2007 | 10:49 AM
Redpit10's Avatar
G35 Convert
Did you reset the PCM since you installed the intake? If not pull out the bottom 15 AMP room fuse or disconnect the battery for about 1 minute. Your car probably needs to learn the new fuel to air ratios. Our 8's are smart and the computer need to adjust most likely.
Old Aug 20, 2007 | 11:39 AM
mysql101's Avatar
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
