I just installed JIC FLTA2 Monotube 15 way dampning adjustable coil over suspension kit!Front damper piston size is 45mm spring rate is 10kg/mm came with pillow ball aluminum upper mount damper bracket is CNC machined aluminum!Rear damper also 15 way dampning adjustable use 40mm piston. damper bracket is beautiful cnc machined for rear special made spring! upper mount I used stock. my car ride height is front is 1.6 inch low than stock.
rear 2 inch low than stock. ride feel FWY drive is very very nice. I love very much!
santino
10-09-2003, 03:49 AM
any pictures of the car with the coilovers on?
santino
mikeb
10-09-2003, 05:14 PM
can you post price and where you got it
any pics like santino said please
syntrix
10-10-2003, 09:10 PM
Where did you get them from?
I'll buy RIGHT NOW@!!@!@@@
The jic 2's were pure bliss on wrx's. These look good, too!
syntrix
10-10-2003, 09:11 PM
wait... why did you use the stock upper mounts?
reason using rear stock upper mount if they said better ride feel and doesn`t want to make too short stroke damper for RX8 chassis.right now my car ride feel is almost same feel and much more better hudling. I will maintenance car tomorrow and will attached photos. my car JIC testing USA Ver FLTA2 for USA road.
they said, will start sell from NOV.from NOV to Next year untill end Feb they said, they will set up introduce price for new RX-8 FLTA2 kit. also they said from DEC start sell Full Titanium muffler.
mikeb
10-11-2003, 05:57 PM
thanks for the inside info
syntrix
10-13-2003, 06:58 PM
That's a month away!
I might hold off for the jic's!!!!!
