Utility Power Outlet Not Working
Old Aug 16, 2007 | 02:23 PM
rotarykillz's Avatar
Rotary Freak
I just bought an 04 RX-8 about 4 months ago. I've found that the Utility Power Outlet in the Center Console is not working. I've heard of it coming stock disconnected and it's not something everyone would use. Any ideas or suggestions?
Thanks,
Derek
Old Aug 16, 2007 | 02:24 PM
StealthTL's Avatar
Metatron
First place to look is the fuse box by the drivers feet.
Check the contacts on the back of the plug, it's fairly easy to pull out, see if it is connected.
S
Old Aug 16, 2007 | 02:28 PM
WikkedOne's Avatar
Deals on wheels
yeah - the previous owner may have disconnected it to run a remote line for a system in the trunk - just pull the plug out (just hook your fingernail on the peice of plastic that holds in it at the bottom and it will pull right out) and make sure both of the wires are still connected. and if they are then check the fuse box
ladnarf1
Apr 29, 2021 11:53 PM
drebbrnator
Dec 27, 2018 07:02 PM
Billy Marcial
Mar 1, 2018 06:50 AM
uZu
Dec 30, 2015 12:35 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
