cap fried, nothing working
Old Aug 8, 2007 | 07:32 PM
rkhockey12's Avatar
well my capacitor just fried completely like acid dripping everywhere in my trunk...this is right after i put the main fuse back in which i blew by accidently hooking up the battery + and - switched..i realize that at this point everyone reading thinks i am the biggest dumbass and this is my first time everything..not the case..i was tired and the posts were switched on the battery which i didn't notice and i have no idea why the cap fried because its got a solid ground..anyways the head unit will not even turn on anymore as well as nothing else..i think its because one of the amps it was hooked up to wasn't grounded yet due to bad communication..so would that make sense for the amps not to turn on and everything sits in the cap for 15 seconds then finally blows..any ideas?? im in some deep **** right now thats all i know
Old Aug 8, 2007 | 07:40 PM
staticlag's Avatar
The Professor
have you replaced the stock fuses in the drivers kick panel and the ones under the hood?
Also, was your system that you installed properly fused?
Old Aug 8, 2007 | 07:50 PM
rkhockey12's Avatar
my buddy said he had the cap hooked up correctly..nope that would be too easy..pos. and neg. mixed up..which now i know why the cap blew....i don't know how much damage that did to the rest of the system..but yes its properly fused and no i haven't viewed the other fuses yet..which fuse would cause the HU to not even turn on anymore?
Old Aug 8, 2007 | 07:55 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
After reading this post and the other post, seems like you need to download a manual from www.mazdausa.com unless you got one? It would show you in there.
Old Aug 8, 2007 | 08:32 PM
staticlag's Avatar
The Professor
well, there is A LOT of charge in a capacitator. And as you may know by now, it hooks up in parallel to your existing power circuit, not in series.
Describe your system, and how its hooked up, power sources, grounds, fuses.
If it was was properly fused then it should just be the fuses,
But since the cap was backwards, the capicator would have wanted to charge itself once it was connected to power, and would have pulled electricity from the ground through other wiring to try and charge itself.
Chances are that:
a) you blew a ton of fuses around your entire car, and possibly melted some wiring.
b) your car was not properly fused/wired or it pulled too much current through a little accesory and toasted it.
I suggest you pull all the fuses from your car and check them, if they are all good then you will probably need to replace a few things. That and never let that friend touch your stereo system again.
Old Aug 8, 2007 | 08:49 PM
rkhockey12's Avatar
alright thanks
none of the wires are melted and im in the process of checking all the fuses
power comes from the battery hits a fuse (250A) and goes into a distribution block, one way goes to the 4 channel and the other way goes to the cap, off the cap it goes to both amps with no fuses intercepting it. so there is a chance i messed up both amps correct?
Old Aug 9, 2007 | 02:16 AM
WikkedOne's Avatar
Deals on wheels
its hard to tell man.. I think you should unhook everything, and then hook it all back up one piece at a time, double checking everything as you are doing that. - good luck man
Old Aug 12, 2007 | 10:59 PM
rkhockey12's Avatar
well good news it was a few fuses in the kick panel..the process continues, we finished the box today and its awesome we made it all out of wood and we have curving steps to fit the contour of the trunk..we have to carpet it tomorrow and then it should all be good to go..i know getting the box is gonna be close..we have to take off the trunk trim but it will fit..so ill make sure i post a bunch of pictures when its done..thanks guys for the help
Audio Concepts ATL
Sep 26, 2021 01:59 PM
MANIACman
Nov 11, 2015 10:58 PM
wankelbolt
Sep 9, 2015 03:43 PM
Kangarhew
Jul 18, 2015 08:27 PM
AussieGray
Jul 16, 2015 03:58 AM
