corksport problem
Old Aug 4, 2007 | 04:49 PM
rkhockey12's Avatar
corksport problem
i've been searching and can't find a clear answer to this problem i had when installing the Pioneer AVIC-D3 with the corksport adapter
there are two wires one that says it has to go to the reverse signal wire in the trunk and one that has to be hooked up to the parking brake..
i figured that since the corksport was made for the rx8 only that i would just match those two wires with the same colored wires coming out of the 24p connector.
is that accurate or do i have to run one to the parking brake and the other two the reverse signal in the trunk?
Old Aug 4, 2007 | 05:00 PM
WikkedOne's Avatar
Deals on wheels
no you cannot use the wires in the harness (i don't think)
the parking break is easy, its in the center console running from the ebrake twards the ashtray (although you might want to check out AVIC411.com to see if there is a bypass or something first)
the reverse you only need if your going to add a reverse camera otherwise it's useless. And yes you have to run it to the trunk, or you can find the wire in the wire bundle in the drivers side kick panel
theblinkof
Oct 4, 2023 05:24 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
