Help - Removing Head Unit ASAP
Old Aug 2, 2007 | 05:19 PM
PatInTheHat's Avatar
I am currently following the steps in the DIY Head Unit Removal thread:
https://www.rx8club.com/showthread.php?t=7644.html
I am stuck on the step where you remove the "silver bolt" from behind the unit. The instructions make it seem like it is very obvious which one it is but I cannot figure this out.
From what I can see theres several different bolts too and I have no idea which one it is, and even if I figure it out I can't seem to get at any of these bolts to remove them.
Can anyone help?
Old Aug 2, 2007 | 05:22 PM
StealthTL's Avatar
Metatron
Next to the drivers right knee is the slits for the AudioPilot microphone, it's just about behind that on the unit.
You have to get your head right in by the clutch pedal, then look back at the unit. Use a closed-end wrench.
Don't put it back once it's out.....
S
Old Aug 2, 2007 | 05:30 PM
StealthTL's Avatar
Metatron
Pic....
S
Attached Thumbnails Help - Removing Head Unit ASAP-%2520hidden%2520screw.jpg
Old Aug 3, 2007 | 01:14 AM
w0rm's Avatar
PUSHER ROBOT
note that the metal sheild BEHIND the plastic paneling has also been removed. I was unable to reach it or see it at all until the metal was partially removed(I removed the right two screws and slightly bent the sheild out of place to access the nut).
Just hardwired my aux in tonight, had great fun pulling apart all the cupholder/armrests.
Old Aug 3, 2007 | 02:21 AM
Thanks a ton Stealth! Exactly what I needed.
Old Aug 3, 2007 | 02:33 AM
NgoRX8's Avatar
i still have that bolt in my coin box from installing my audiolink. seriously a pain to get to.
Old Aug 5, 2007 | 08:31 AM
firebirdude's Avatar
User and Abuser
Originally Posted by StealthTL
S
AWESOME pic to show location of that damn bolt. Im sure many will thank you.
RenzoRx-8
Sep 9, 2015 02:38 PM
mattymack
Sep 6, 2015 10:33 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
