Possible problem after install?
So i followed all of the threads and the DIY's and my amp is still not working.
-I connected the LOC's and the RCA cables are secure. the t-taps are good, i'll try soldering them tonight if this is the issue. but i know it's not.
-The 4g power cable is ran through the firewall and the fuse is still good.
-the ground is set and grounded.
-the remote wire from the amp is connected to the pink/black wire of the amp harness... now this was my concern, since the pink/black wire is only hot once the ACC is turned on. so could this be my problem? the amp light turns on, but no power to the subs.
another 8 member said he used this wire and it worked out fine, but i havent heard back from him yet. anyone else know?
should i run it to a 12v wire with a toggle switch then?
what should i do? help!
If the amp turns on, the wire is fine. T-taps are the worst connection known to man. Get them out of there like pronto. Wear rubber gloves and full protective clothing when you do. Carefully place in trash can and secure lid down so that they do not make a break for it and find their way into a different install. If the rca cables are grounded out or hooked to the wrong wires, yes expect to get noise. If you have a ipod or any other portable device, find a mini stereo to rca adaptor cable and plug it into the amp. If no sound, then it is a bad amp or bad sub. If there is sound, then it is a bad LOC, rca cable dead shorting or bad (or wrong) wire connection.
so i took the T-Taps out and used a different wire connector and it works! lol. i should have known those damn taps wouldnt have worked. oh well, was the first time trying them out and will be my LAST.
now that the audio works... im just a little dissappointed on the Bass level.. i want MORE!
alot of people claim they get poor signal when they tap before the bose amp. if you had a good LOC it can correct this, or you can tap after the amp, but your going to get alot of distortion and weird stuff...
I'm not at home at the moment, but lets see...
I followed the Sticky's version of the install. i tapped the LOC to the signal before the Bose amp. - to - and + to +.
it's a 500WATT 2-Channel amp. I adjusted the gains, but I dont have a Bass controller, it broke on me so i cant adjust it manually... is there another way i can adjust the Bass level on the Amp itself?
I will definately check out on the Audio Control 6XS Interface adaptor.
For the billionth time, a LOC is for converting speaker level inputs to a pre amp signal. This is not what you have before the bose amp, so it will not give optimal results, even if some people have had good (to them) results.
Use a line driver before the amp for the cleanest signal.
Most bass controllers are universal.
If you have Rockford Fosgate amps I'll send you one free
Originally Posted by jstkilntim
"Use a line driver before the amp for the cleanest signal."
A LOC is designed to take higher voltage signals and turn them into lower voltage signals for amps (or other equipment) that is not designed for high voltage inputs.
The Bose HU does not have a high voltage output. Therefore taking a low voltage signal and lowering it even more just to get RCA plugs is not an ideal situation & will not give the results that most are looking for.
Since the HU output is fairly flat & full range, for less tha $10.00 you can easily add RCA plugs to your bose (pre amp) wiring for better results than using a LOC. If you are using good equipment that accepts a higher voltage input, you are best off using a line driver to boost the signal to the amp. Line drivers are designed to boost voltage w/ minimal noise increase. This in turn allows you to lower the gains on your amp which usually reduces overall system noise.
You will notice that most competition systems have several line drivers to achieve optimal results.
Also, w/ all of that being said, there are a few manufacturers w/ LOCs & line drivers in the same unit. If you don't mind spending the money, which is well worth it in the end, these are definitely easier to install since they have speaker level inputs.
xAgyex
Jun 3, 2026 03:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
