Tein H Tech Springs
Old Jul 30, 2007 | 05:43 PM
M Fury's Avatar
Tein H Tech Springs
Please someone tell me that these springs settle. Right now my ride is no lower than before the install.
Old Jul 30, 2007 | 05:53 PM
dillsrotary's Avatar
jersey fresh
they are only a small drop to begin with, who installed the springs?
Old Jul 30, 2007 | 06:04 PM
M Fury's Avatar
A local shop. I know it is just a little drop (1" front and 0.3" rear). However, there is absolutely no difference. I'm totally bummed.
Old Jul 30, 2007 | 06:07 PM
Never fear, Jedi is here!
Your ride height didn't lower because the shop most likely did not pre-load the springs. Turn your wheel completely to one direction. Get in there and loosen the two upper control arm bolts. (very easy to do, no need to go back to the shop) I think it's a 17 mm???
Loosen then 80% of the way, let sit for 30 minutes, retighten and BINGO, your car will lower slightly and the springs will settle within a few days / week depending on how much you drive.
Old Jul 30, 2007 | 06:31 PM
M Fury's Avatar
Hopeful advice. Does this include the rear as well? Thanks
Old Jul 30, 2007 | 06:42 PM
nope, not possible to preload the rears.
I've seen this happen a LOT with shops installing springs because normally everything is done while it's on a lift so there's no weight on the springs when they tighten them down.
Trust me, if they're installed properly, this should help fix it.
Old Jul 30, 2007 | 06:45 PM
jersey fresh
jedi is the man
Old Jul 30, 2007 | 06:48 PM
Originally Posted by dillsrotary
jedi is the man
I aim to please.
Old Jul 30, 2007 | 07:33 PM
M Fury's Avatar
Just want to make certain. These are the bolts tha connect the a-arm to the chasis right? Thanks
Old Jul 30, 2007 | 07:40 PM
jersey fresh
pics attached. Its the bolt i'm pointing to and the same one on the other side, then loosen the same two bolts on the other side of the car.
Old Jul 30, 2007 | 09:01 PM
Silver_Surfer's Avatar
I4NI
Old wise one. Do you think he should repeat pre-load process after springs have settled in?
Old Jul 30, 2007 | 09:59 PM
M Fury's Avatar
Thanks for the pic, bro!
Old Jul 30, 2007 | 10:50 PM
yup, don't see why not.
Old Jul 30, 2007 | 10:56 PM
NgoRX8's Avatar
rotary rasp had his s-techs for a few months and didn't notice the drop that there should be. that is until i loosened the control arms for him. haha
Old Jul 31, 2007 | 12:52 AM
M Fury's Avatar
Thanks again for all your help. I'll post pics soon.
Old Jul 31, 2007 | 02:54 AM
rx8spiritR's Avatar
----Got Rice?----
pictures!!!!!!!!!!
Old Jul 31, 2007 | 12:51 PM
GRGJTSN's Avatar
vV Me on the Dragon Vv
Same thing happened to me when I got my Eibachs installed--rear looked good, but front looked same as before (supposed to be 1.2" drop). So I took it back to the shop and asked him to loosen the front upper control arm bolts while the car was on the ground, and it pretty much immediately dropped about an inch. Tightened 'em back down and was ready to go.
Old Aug 5, 2007 | 05:13 PM
M Fury's Avatar
Pics as promised. The preload helped the front. The rear is still higher than when stock springs were on. Hopefully, they settle. Note on performance: Nice plush ride. Even better than stock springs. However, I would like it a little lower. 3 tenths of an inch all the way around would make me content.
Old Aug 5, 2007 | 05:26 PM
perks11's Avatar
HEADTURNER
nice. yea the back does look high, but i like
Old Aug 5, 2007 | 05:36 PM
jersey fresh
Then I suggest going with s-techs if you want it lower
Old Aug 5, 2007 | 05:41 PM
M Fury's Avatar
Just want to give a huge thanks to Jedi for advice and Dillsrotary for the pic. You guys rock!!!
Old Aug 5, 2007 | 05:43 PM
M Fury's Avatar
Thanks, bro!
Old Aug 9, 2007 | 02:25 AM
faboo's Avatar
Downhill Touge FTW!!
how much were those bbs's??
Old Aug 9, 2007 | 03:28 AM
thebiggdaddy's Avatar
yeah, i was wondering the same thing. love the wheels, but lose the bra!!
Old Aug 11, 2007 | 11:52 PM
M Fury's Avatar
Bought them off a friend for 1,200 with tires (good deal).
As far as the bra, it's that time of year in Louisiana when love bugs are extrememly active and they will totatly mess up your paint. I take it off once the season passes.
