Adding a fan controller....
Old Jul 30, 2007 | 03:52 PM
Hercules's Avatar
I have fans on my rear deck for intake and exhaust of the trunk, so there's some air circulation. I wanted to put them on a fan controller, but I have a question...
The fan controller has a 4 pin molex connection, 12V, Ground, Ground and 5V. I don't have a 5V, obviously. Do I need the 5V? I was thinking I'd wire it up to the 12V and ground and see if it runs. Anybody have any experience with this?
Thanks a bundle!
Old Jul 30, 2007 | 04:51 PM
WikkedOne's Avatar
Deals on wheels
the 5V makes it run slower, so it has a high speed (12v) and a low speed (5 v) if you want to hook it up, your probably just need a universal plug - it will let you select 5v
but if you don't want the 2 speeds, then don't worry about it.
Old Jul 30, 2007 | 05:08 PM
StealthTL's Avatar
Metatron
I don't think the 5v would even be connected to the fan, no fans run on it.
If you only have 2 wires, it's 12v.
I also wouldn't put one in/one out, I'd go with two out from trunk to window area.
They would pull from the top of the trunk space, with fresh air coming in from the cabin. (All the air that comes in the vents/defrosters leaves thru the two rubber covers into the rear bumper area.)
S
Old Jul 30, 2007 | 05:47 PM
Hercules's Avatar
Stealth, you will have to explain that to me a bit better...
My logic was that I'd use one in and one out to get circulation into the trunk, nothing else.... That way hot stale air exits, cold air gets in there and keeps doing that, keeping the trunk much cooler.
Let me know what you think and the logic behind it... I'm missing something from your post I think
Old Jul 30, 2007 | 05:55 PM
redferne's Avatar
If you do both fans exausting from the trunk. This could double as a rear window defogger.
Old Jul 30, 2007 | 06:24 PM
Hercules's Avatar
I'm going to put it on a switch.... during cold months it won't even be on, no need
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
