Mazsports cooling fan mod caused CEL?
Old Jul 25, 2007 | 03:47 PM
HERO's Avatar
So I've been going back and forth to the dealer to fix a cel Ive been having. They would keep resetting the ecu and it would come back in a couple days. Today, they actually pulled codes! They pulled a P0456 which they replaced the gas cap to fix. Then, they pulled the codes P0480 and P0481 and blamed them on the mazsports cooling fan mod and did not do anything to fix it. I havent heard anything about the Mazsports cooling fan mod causing any CELS so I was wondering if anyone knew anything about those codes?
thanks
Old Jul 26, 2007 | 02:42 PM
Celronx's Avatar
Unregistered User
Those are the codes for the cooling fan relays having to high or to low voltage. I've had the same ones pop up with mine once. I cleared them and haven't had them come back up. These codes will not cause the MIL to light up, it just stores them in the memory. I don't know if they will cause you to fail an inspection or not, but I would guess not. The CEL you had was for the gas cap and these were just stored in memory with the other code. You might call Mazsport if you keep getting the codes.
My fans have been working fine and I haven't gotten any more codes so I haven't worried about it.
Cel
Old Jul 26, 2007 | 02:44 PM
MazdaManiac's Avatar
That is why I use a pair of diodes in my fan mod.
BTW - the CEL/code will fail you in an emissions test.
Old Jul 26, 2007 | 02:47 PM
Celronx's Avatar
Unregistered User
I didn't know that. Thanks, that'll probably save me a trip when I get my inspection.
Old Jul 26, 2007 | 04:55 PM
brillo's Avatar
Go Texas Longhorns!
can you use the typical ECU reset procedure with the cooling mod removed to clear the code prior to a emissions test?
Old Jul 26, 2007 | 06:48 PM
Yes, but remember you won't pass an emissions test immediately after a CEL if you live in a state with an OBD-II test.
It takes a minimum of three drive cycles to set all the flags to "OK" after a reset.
Old Jul 26, 2007 | 10:05 PM
HERO's Avatar
diodes? can you explain to someone who doesnt understand
Old Jul 26, 2007 | 10:09 PM
Probably not.
Old Jul 26, 2007 | 10:23 PM
chickenwafer's Avatar
Nope
I have the same diode manual fan switch as MM (Probably because he did it for me) and I've never gotten a CEL. And it costme $5 bucks for the universal switch from RadioShack
Old Jul 27, 2007 | 03:57 AM
put the stock relays back in... see if that solves the problem...
i have i think about 25k miles on the cooling mod. have not had that issue..
Old Jul 27, 2007 | 07:24 AM
mysql101's Avatar
I haven't gotten a CEL from it either.
Old Jul 27, 2007 | 10:23 AM
Jax_RX8's Avatar
Got Another Rotary
No issues or CELs here
Old Jun 30, 2011 | 12:35 PM
ROAD WARRIOR's Avatar
Does one of the later flashes lower the operating temperature?
I have the kit but have not installed it. It was bought 3-4 years ago.
I live in CT & it doesn't get that toasty around here.
I have not had my 2004 in the dealership since late 2009.
Feed back?
Old Jul 1, 2011 | 12:10 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Thread alive again after 4 years of hibernation!
Anyway, i don't have any answers to your question...lol
gwailo
May 14, 2024 06:57 AM
RX-Tuner
RX8Performance
196
Apr 16, 2023 02:19 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
Nisaja
Aug 6, 2015 01:27 AM
dbarber
Jul 25, 2015 01:34 PM
