RX-8 Trouble
Old Jul 24, 2007 | 06:20 PM
RX813en's Avatar
RX-8 Trouble
I have been reading around and i have noticed people talking about redlining the 8. However I think I did this once and here is what happened.
I was driving onto the road and got on the median, by this time i went up to about 18mph. Then i saw my chance to get in the lane and put it back in first gear and stepped on it and i didn't see it redline, or hear the noise it makes when you redline a car, but i heard like a pop. I thought i had ran over something that popped my tire cause then i heard what sounded to me like the air was coming out of the tire, but pausing every half a second when the hole would touch the ground and keep the air from coming out. Well then my check engine light, and my battery light, and i think the oil light, turned on. Then my car turned off. So i got it taken to the shop and they told me that there was a "misfire" that caused some sparkplugs to blow out, some screw somewhere got loose, and i don't remember what else. It was some time ago. Has anyone had this problem, and was it caused by redlining it, or did i do something else
Old Jul 24, 2007 | 06:33 PM
mac11's Avatar
Rotary , eh?
so you are saying you have only had your car at redline once? and never again?
Old Jul 24, 2007 | 06:49 PM
RX813en's Avatar
yeah, you think something else was wrong with the 8, or u thinks its safe to do it again?
Old Jul 24, 2007 | 06:54 PM
mac11's Avatar
Rotary , eh?
How long have you had your car?
I'm sure it safe. I do it multiple times daily. If you've had the car for a while the problem could be that you DON'T redline it. You could have accumulated carbon in the combustion chamber and when you took it up to redline created a hot spot which could have casused detonation or pre-ignition.
If the car is relatively new you may have had a faulty spark plug or a bad tank of gas. Lots of possibilities.
Old Jul 24, 2007 | 06:59 PM
RX813en's Avatar
I got it used so i don't know how the previous owner drove it, ive had the car since december. I need to find a place to redline it cause around here the cops are everywhere. So redline at 1st gear once a day?
Old Jul 24, 2007 | 07:13 PM
mac11's Avatar
Rotary , eh?
You've had the car since december and haven't found the redline but once? I can't even fathom that. All the power in this motor is above 6K! The peak power is made at 8500!
I didn't say you had to slam your foot on the floor like you are drag racing, just don't **** it until you hit a higher RPM. You never drive on an interstate or major 2-lane (in each direction) road with a 45+ speed limit?
Old Jul 24, 2007 | 09:11 PM
cajunrx8's Avatar
Rotary Crawfish
I redlined my car on the testdrive!! As least 3-4 times,and the car asked for more.
Old Jul 25, 2007 | 11:55 AM
Alano's Avatar
07 Phantom Blue Owner
Isn't putting it down in first gear at 18 mph bad? ::
Old Jul 26, 2007 | 03:33 AM
Kiken_808's Avatar
I just wouldn't even have shifted to second. I would've left it in first and shift it into second at about 25mph. That's just me. What does everyone else think?
Old Jul 26, 2007 | 03:38 AM
did you get the crossfire code???? lots of light combos in the dash. a bit like tic tack toe.
Old Jul 26, 2007 | 10:43 AM
RX813en's Avatar
Three lights turned on, but im not sure i know what the crossfire code is.
Old Jul 26, 2007 | 12:56 PM
reaper1's Avatar
I'm with you on this one , I won't redline in first. Second , third , Yes
Old Jul 26, 2007 | 01:18 PM
mac11's Avatar
Rotary , eh?
what so bad about redlining first gear? with the gearing reduction the motor actually sees less load in 1st than in 2nd and less in 2nd han 3rd etc etc.
Old Jul 26, 2007 | 01:21 PM
I redline 1st and 2nd gear EVERY day. I would not however, upshift back into 1st at almost 20mph.
Old Jul 26, 2007 | 10:26 PM
LiveBlues's Avatar
Me too, on both counts.
Old Jul 26, 2007 | 10:45 PM
dynamho's Avatar
There's a dude here in New York. He said he never revs past 4k and he seems to be proud of babying his engine. He brags that he gets 20mpg in the city if he doesn't rev past 3k. WTF?
I wonder if his Renesis will pop if he redlines. Hahaha!
Old Jul 26, 2007 | 11:07 PM
mac11's Avatar
Rotary , eh?
I wonder why he bought a sports car?
Old Jul 27, 2007 | 02:55 AM
Stavesacre21's Avatar
1.21 Jiggawatts
Don't know as though it actually is a harder shift, but it always feels like it. When it comes to a notchy shift, the 1-2 is always a little bit worse.
I don't know as though it's any worse, but I know that doing the 1-2 shift is harder on the 2nd shift syncros because of it's frequency. In a few of the other cars i've had, that specific syncro has always been one of the first to go. Hope this tranny is made to take it...i know it has triple syncros in the first 3 gears.
Old Jul 27, 2007 | 07:14 AM
reaper1's Avatar
I just don't get a good feel on the first gear . It's seems like I'm beating it up to much , if I redline on that gear .
Old Jul 27, 2007 | 08:41 AM
mac11's Avatar
Rotary , eh?
You should search this around here, some people have had problems. I redline 1st gear but am generally very gentle on my 1-2 shift.
Old Jul 27, 2007 | 09:59 AM
mwc's Avatar
mwc
Not if you double-clutch. If you double-clutch and it goes into gear smoothly, you know you did it right and were kind to your synchros. Then, match revs before letting your foot off the clutch. Works like a charm.... and it's fun.
Cheers
Old Jul 27, 2007 | 10:05 AM
Nopstnz's Avatar
I agree. I redline first all the time. And also, I've put it into first at 18 mph, but yeah, it is smart to double clutch. People mention first being blocked over 12 mph, but I've never had that.
Old Jul 27, 2007 | 10:17 AM
sleddog_racer's Avatar
sleddog_racer
My experience has shown the RX transmission to be more 'old sports car' like; it doesn't really like 1st gear unless you are at a standstill (oh ya, it will DO it, but doesn't like it) and 2nd is so low anyway that the revs build quickly into the power band. You can indeed double-clutch while downshifting with OK results but I find that if I just rev-match while downshifting (works great with heel-and-toe) the trans just falls into the next gear slick as anything.
Old Jul 27, 2007 | 10:24 AM
mwc's Avatar
mwc
I mostly agree. I rely upon the synchros when downshifting into 2, 3, and 4 and just simply match revs. However, I find it necessary to double-clutch when downshifting into 1st unless I'm either crawling or at a stop.
Cheers
Old Jul 27, 2007 | 10:27 AM
dmc27's Avatar
doin' the bull dance
whatever the problem, it was not caused by redlining. maybe it was just a backfire & plugs and not related to more serious issues, maybe not. the only way to find out is to take it up to the redline again. doesn't need to be foot on the floor acceleration - it can still be a nice smooth run up to 8k. you don't have to go right to the beep, just need to get to 7-8k preferably in 3rd. highway is recommended for that, tho.
downshifting to 1st is fine. tho (imo, of course) completely unnecessary in routine driving. & +1 to mwc - it can be fun. especially the high rpm screaming as you DS to 1st coming up to a stop.
