BlueRenesis82
07-23-2007, 10:33 PM
NASA Midwest is running August 4th and 5th, at Road America.
Shout out if you are coming!
View Full Version : NASA Road America August 4th and 5th BlueRenesis82 07-23-2007, 10:33 PM NASA Midwest is running August 4th and 5th, at Road America. Shout out if you are coming! devildog1679 07-23-2007, 11:01 PM I'm still talking to Erin about it. It's our Aniversary so I need to cater to what she wants. Red Devil 07-25-2007, 10:10 AM Maybe...I'm not 100% whether I'll have my car back by then or not...will make it kind of difficult to get up there unless RSD or Mac are heading that way...I'd like to go, though. BlueRenesis82 07-25-2007, 11:24 AM any idea when you will have a better idea? Red Devil 07-25-2007, 01:54 PM I asked for my PCM to be returned right around or before that time...as such I don't think I'll know until the last second. devildog1679 07-25-2007, 11:10 PM Lets cross our fingers Blue, you need to book your room I had a hell of a time getting a room. We decided just to get one ourselves being that it's our aniversary. Nick R 07-26-2007, 12:16 AM I may end up coming up with some of my friends from Club3G to check it out. Dependant on whether or not I end up going to Iowa that weekend. devildog1679 07-30-2007, 07:28 PM Looks like rain this weekend :( I'll hold off on registration untill Thurs. in order to get a better idea of weather. BlueRenesis82 07-31-2007, 09:26 AM I may end up coming up with some of my friends from Club3G to check it out. Dependant on whether or not I end up going to Iowa that weekend. You should come More_Revs 07-31-2007, 10:26 AM I'd come watch, but I'm busy Saturday and have autocross Sunday. Hey devildog, I'm going to the Madison Club autox at Fond Du Lac next Sunday if you want to join me. devildog1679 07-31-2007, 12:41 PM I'd come watch, but I'm busy Saturday and have autocross Sunday. Hey devildog, I'm going to the Madison Club autox at Fond Du Lac next Sunday if you want to join me. I may actually come by then. That's the 12th right? How much to participate? More_Revs 07-31-2007, 01:36 PM $35 for non-member. http://www.madisonsportscarclub.com/autocross/schedule/ mac11 07-31-2007, 01:40 PM Wow, missed this thread. I guess we all know whats going on already though. devildog1679 07-31-2007, 04:18 PM Wow, missed this thread. I guess we all know whats going on already though. You going to RA? mac11 07-31-2007, 04:21 PM I'll be there and I'll be working in some capacity. RedSheDevil 08-01-2007, 10:31 AM I'm there. devildog1679 08-01-2007, 12:59 PM OK great, we'll be there early Friday afternoon, I won't be driving until Sunday. Saturday we are doing some other things in celebration of 1 year of putting up with each other :cuddle: We may stop by at some point during the day on Saturday depending on what is going on. On a side note, I have a possible stupid question. I noticed know that my steering wheel is no longer centered:scared: Meaning, that for the car to track straight the wheel is turned a little to the left? If I try to center it the car turns right? Do I need to get an alignment? mac11 08-01-2007, 01:04 PM Yes sir - most likely. Its possible a belt slipped in one of your tires or that they have worn unevenly. The uneven wear is HIGHLY unlikely since we just looked at them the other week and they were fine. Belt slipping or breaking is possible but you would probably be noticing a lot of vibration whenever you get over say 50mph(which we know you do...constantly). My guess is you got into a pothole that fubared something. talk to me about it at the track if you can find me. devildog1679 08-01-2007, 01:11 PM Yes sir - most likely. Its possible a belt slipped in one of your tires or that they have worn unevenly. The uneven wear is HIGHLY unlikely since we just looked at them the other week and they were fine. Belt slipping or breaking is possible but you would probably be noticing a lot of vibration whenever you get over say 50mph(which we know you do...constantly). My guess is you got into a pothole that fubared something. talk to me about it at the track if you can find me. Ok, Thanks. One other question, I switched back to street pads after autobahn and now my brakes squeal. Not while braking but while wheels are turning with no brake pressure. Do you think the XP8's deposited some material that the stock pads can't scrape off thus causing the squealing. Do you think I can try some aggressive stops to see if that alleviates the issue? BlueRenesis82 08-01-2007, 01:16 PM Ok, Thanks. One other question, I switched back to street pads after autobahn and now my brakes squeal. Not while braking but while wheels are turning with no brake pressure. Do you think the XP8's deposited some material that the stock pads can't scrape off thus causing the squealing. Do you think I can try some aggressive stops to see if that alleviates the issue? You really should have either 1 manuf. of pads, or different rotors. Otherwise the different pads materials will cause issues. I know, I have had that happen to me several times mac11 08-01-2007, 01:24 PM Either that or the track pads are worn further down that the street pads and the piston did not get pushed quite far enough back into the caliper causing the daily pads to rub on the rotors more than usual. devildog1679 08-01-2007, 01:25 PM You really should have either 1 manuf. of pads, or different rotors. Otherwise the different pads materials will cause issues. I know, I have had that happen to me several times Yea, I'm thinking next step is to get dedicated front rotors for the track. mac11 08-01-2007, 01:30 PM Or sandpaper. Sandpaper is much cheaper. .02 devildog1679 08-01-2007, 02:36 PM Off to Home Depot then. mac11 08-01-2007, 02:56 PM make sure you don't get woodworking sandpaper. And something like 100-150grit should be sufficient. devildog1679 08-01-2007, 05:51 PM I'll actually do the sanding after this weekends track day. Weather is looking good for Saturday, Sunday looking OK. |
