2nd Oil Cooler
Old Jul 22, 2007 | 08:26 PM
precisi0n84's Avatar
2nd Oil Cooler
Anyone get an extra oil cooler installed?
Where and how much?
Old Jul 22, 2007 | 08:37 PM
heyarnold69's Avatar
Rotary wanabee
Greddy oil pan!!!! wow what a diff! Even if your runnign a basic stock setup .. it helps keep the oil a lil bit cooler and you can use more oil .. i still kept the oil change intervals the same .. but really I could go longer.. the oil pan is semi clean unlike the black goop that resulted before...
ebay ... 300 sh ... other dealers have them for as much as 400
*** note the 300 includes the price of a new gasket
Last edited by heyarnold69; Jul 23, 2007 at 06:57 AM. Reason: added tidbit of info
Old Jul 22, 2007 | 11:42 PM
sosonic's Avatar
I have a 2nd (mazdaspeed) oil cooler for my AT RX-8 that I got from my Mazda dealer. I would recommend it, heat is a major rotary issue. In fact, I think Mazda lost its mind in taking the 2nd oil cooler out of the ATs and 5 speed Manuals.
Ask a Mazda dealer for price.
The only way I see not going Mazda parts would be if a 3rd party can be proved to have a definitely better or equal and cheaper oil cooler. I would like to see specs on any oil cooler people claim to be better than the Mazda one.
heyarnold69, good point. Anybody else change their oil pan?
http://www.rx7store.net/product_p/gr...0oil%20pan.htm
Finding different ways to cool down the hot rotary is usually a good idea.
Old Jul 23, 2007 | 12:06 AM
takahashi's Avatar
I just run the MaZdaspeed oil cooler like you and have no problem with oil temp in the hottest summer track days.
The hottest I have got is 125 degree C.
But I think oil pan, bearing the fact that if it does not decrease the oil pressure, is also a good addition. There are about 6L of oil as it is in teh system with 2 oil cooler.
Old Jul 23, 2007 | 06:54 AM
Zero_Rotary's Avatar
Double 8
im using HKS extra oil cooler...hottest days i got was 110 deg c
Old Jul 23, 2007 | 07:12 AM
takahashi's Avatar
That is not good enough... if you were on the track on that day, it will go over the roof.
I think 2 cooler is not enough, whereever you are zero_rotary
Old Jul 23, 2007 | 07:27 AM
StealthTL's Avatar
Metatron
There is a guy in the States (see the parts forum) parting out a six-speed, and since every car on this continent already has two, the second one will likely never sell.....
S
Old Jul 23, 2007 | 09:26 AM
Double 8
takahashi...i was actually driving on high RPM constantly taking a beat on it...im from Borneo island no proper track here
Whats the safe limit oil temp anyways? i tot its 120deg c?
Old Jul 23, 2007 | 10:14 AM
takahashi's Avatar
It still cannot stimulate what it is like on the track.
Anyway, depends where your oil temp gauge sensor is. I have mine under the oil filter. MazdaSpeed put their on the sump plug location. The sump will record the closest position to the actual engine temp (so MazdaSpeed said) although the wire tends to damage when you take it out too many times for oil change.
So I think 120 degree on the oil filter is very high. So I normally change engine oil if oil temp is over 115 or so. If you use synthetic - add 5 degree I think as they are thought to be more heat resistant.
Old Jul 23, 2007 | 10:17 AM
rotarygod's Avatar
That's 257*F. That's way WAY WAYYYYYY too hot!!!!!!!!!!!!!!!!!!!
Where are you measuring oil temps? Is that oil entering or exiting the engine? You don't want any higher than 210*F entering the engine.
Old Jul 23, 2007 | 10:23 AM
takahashi's Avatar
Me bad... as I posted before I placed mine on the sandwich under the oil filter. It will be hotter in the engine I will say.
Well I got that high when I was racing in the 33 degree day chasing my PB behind a 350Z.
http://www.youtube.com/watch?v=A7sAJOG3-y4
The coolant temp reached 110 degree at the end. Me very bad , but the oil temp back to 110 degree and coolant temp below 100 after one cooling lap. hehe.
I think I will invest in a radiator next summer.
Your assessment RG?
Old Jul 23, 2007 | 12:19 PM
rotarygod's Avatar
I'd try finding ways to get more air in and out of the engine bay more efficiently. If you are going to keep racing you need to do something. The first thing is to optimize what you have. Only after you've reached that level do you upgrade components. I'd work on some ducting that forced all of the air entering the front of the car to go through the radiator/ oil coolers.
FWIW: When done properly, Mazda LeMans race cars of the past typically ran right around 200*F oil and coolant temps as measured before entering the engine.
Old Jul 24, 2007 | 10:29 AM
Double 8
i only got oil temp 110deg c once while driving very hard on a very hot day...
most of the hard driving reading 100deg c...
normal driving 80-90+deg c...
my sensor is also placed below the oil filter....
according to RG 110 is bad also..hmm...maybe i shud get vented hood ...
Old Jul 24, 2007 | 10:36 AM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
S
Are you sure? My 04 a/t only had one. I added the second.
Old Jul 25, 2007 | 12:37 AM
mdw1000's Avatar
I'll snap his neck.
Can someone post the info on the Mazdaspeed oil cooler? I can't seem to find it on MazdaUSA.com...
Old Jul 25, 2007 | 10:43 AM
sticks888's Avatar
^mazdaparts.com carries it, but it says it's the japanese version. don't know if there is a difference in parts/components. maybe someone can shed some light on whether it's the same?
https://www.mazdaparts.com/CategoryP...+Garage:Engine
Old Jul 26, 2007 | 01:02 AM
mdw1000's Avatar
I'll snap his neck.
thanks!
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
