When starting... supposed to wait?
Old Jul 18, 2007 | 02:59 PM
Booster-X's Avatar
Ghost
If i turn the key to crank right away it won't start. If I wait 1 second when the dash lights come on turn the key, the car starts fine.
Any ideas before I bring it in under warranty?
Yes I did search
Old Jul 18, 2007 | 03:00 PM
Spinning Sushi's Avatar
I <3 Sushi
Mine never does that, I say take it into the dealership under warranty.
I wouldn't know what the problem is though.
Old Jul 18, 2007 | 03:02 PM
NgoRX8's Avatar
hmm, i've never noticed this before.
Old Jul 18, 2007 | 03:32 PM
mikeferz42's Avatar
13BEAST
i know that for my previous car, it said in the manual that i'm supposed to wait 5 secs, (or till some lights come off i.e., check engine, etc.), to have the key on the ON position without cranking the engine. this is true for most acuras because the pcm needs a couple of seconds to check if everything is functioning properly. i fell into that habit with my rx8. i really don't know if the pcm for the rx8 needs a couple of seconds to do diagnostic checks, or if it does it at all, but i do it anyway.
Old Jul 18, 2007 | 03:40 PM
Booster-X's Avatar
Ghost
Makes sense... I'll try to dig this up in the manual...
Its not a big deal... I'll just bring it into the dealer... I'm just used to my A4 i guess...
Old Jul 18, 2007 | 04:34 PM
½mv²'s Avatar
printf("</%i pistons",3);
I've never heard of this for the RX-8.
I've seen in both my RX-7s, though...
...usually means death is just around the corner...
I'd take it in.
Old Jul 18, 2007 | 04:59 PM
RxJaye's Avatar
MOst other cars (non mazda) have a slight delay at times while the ETC (electronic throttle control) cylces and verifies its working properly.
Booster-X's Avatar
Ghost
I wouldn't go that far to say that my engine with 15,000 miles is going to die
Old Jul 18, 2007 | 05:50 PM
MazdaManiac's Avatar
My usual (somewhat subconscious) starting regimen:
Put the key in. Turn to run and wait to hear all of the solenoids cycle. Turn key to start and let the thing turn over 3 to 5 times where it always starts. Wait until the tach settles and/or the air pump turns off. Drive away.
Old Jul 18, 2007 | 05:53 PM
mysql101's Avatar
^ I do the same, but i immediately start to back up the car after it's turned on - don't want the garage filled up with toxic fumes.
Old Jul 18, 2007 | 06:52 PM
delhi's Avatar
Grand Chancellor
It is a good practice to turn the car to ON and wait a few seconds before starting the engine. It allows the electrics to coarse through all the components. I never start right up. Even with my other cars. Never. Especially if you live in cold climates, it is recommended that you prime the ignition for a few seconds first before starting it.
With the rx-8, it's easy. Turn to ON, watch for the gauges to light up then fire up the rotary.
92trbolzr
May 18, 2025 09:04 AM
WranglerFan
Aug 21, 2022 01:29 PM
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
FubarI33t
Sep 28, 2015 08:45 PM
