Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
12mm drill bit?!?!
Old Jul 9, 2007 | 11:59 AM
HERO's Avatar
Question 12mm drill bit?!?!
I was about to install my koni/s.techs when I realized I needed to buy a 12mm drill bit. I've checked home depot, sears, autozone and oreilys and nobody has it!! Does anyone know where I could find one??
thanks
Sam
Old Jul 9, 2007 | 12:00 PM
I got mine at home depot. (when I installed my Koni's)
Tell them you need a bit that will drill 12mm and they'll size one out for you. (I forget which size it is...)
Old Jul 9, 2007 | 12:30 PM
CosmosMpower's Avatar
1935 lbs. FTW!
Try any good local hardware store, we have a place called Elliots down here in Dallas that has everything under the sun. Also try Harbor Freight if you have one in Houston.
Old Jul 9, 2007 | 05:54 PM
midlife crisis's Avatar
That 12mm is .472 inches or about .003 inches larger than 15/32".
Old Jul 9, 2007 | 09:51 PM
HERO's Avatar
Appreciate all the help guys!!
Ill try home depot again tomorrow and see if they can fab one up for me!
Old Jul 11, 2007 | 12:51 PM
Coop '04's Avatar
DELIVERED 07-17-2004
They are not going to fab anything they will do the conversion to inches which someone already gave you a 15/32 that is very close. Use it and wiggle the drill around slightly after you drill the hole and it will be just right.
Old Jul 11, 2007 | 01:04 PM
HERO's Avatar
yea I figured that much. found the 15/32 at lowes yesterday and finished up the install.
thanks again everyone!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Digitz0070
Oct 7, 2015 12:43 PM
FubarI33t
Sep 28, 2015 08:45 PM
WingleBeast
Sep 9, 2015 10:10 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
