Tires for Front Wheel drive - is bigger better?
Old Jun 28, 2007 | 02:35 PM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
For performance and styling big tires are great for rear wheel drives - but what about front wheel drive?
Smaller but wider?
Taller but thinner?
What are the opinions and why?
Old Jun 28, 2007 | 04:02 PM
mac11's Avatar
Rotary , eh?
For performance wider tires will always give more grip. assuming you are placing them on an appropriate rim. drivetrain wont factor into this.
Old Jun 28, 2007 | 04:17 PM
PoorCollegeKid's Avatar
Yep. Some FWD cars, like the Grand Prix GXP (I think that's the trim, anyway), come with larger front tires to help with front end grip when you get on the throttle.
Old Jun 28, 2007 | 08:28 PM
Winfree's Avatar
O.K. so wider tires - but how about size?
Is there some best in the range between 13-17"?
Smaller easier to turn and larger are faster? What are the physics here?
Old Jun 28, 2007 | 08:34 PM
mac11's Avatar
Rotary , eh?
less weight, closer to the center of the circle will always accelerate quicker. Larger overal diameter will give you a gearing advantage biased towards top speed, if you have enough power to spin them.
Old Jun 28, 2007 | 09:47 PM
The smallest rims that will fit over your brakes will be the best. You can change the gearing by switching out your rear end for a different one, but the weight advantage of smaller rims will be there regardless. Smaller, lighter rims and tires decrease the amount of mass your engine has to accelerate and your tires and steering wheel have to turn, which will help both performance and gas mileage. Some of the Lotus guys actually will run smaller rims and tires than stock for these reasons. This works for any car, not just FWD ones.
Old Jul 1, 2007 | 09:45 PM
yiksing's Avatar
the giant tastetickles
Smaller but wider?
Taller but thinner?
What you gain in the dry, u lose in the wet. Weigh out your priority and decide which to use
Old Jul 2, 2007 | 02:41 PM
MazdaMonkey's Avatar
Resident Monkey
F1 cars use 13" diameter wheels if remember correctly.
Old Jul 2, 2007 | 03:16 PM
OldCoot's Avatar
Required by the rules.
Old Jul 2, 2007 | 04:18 PM
Have a link? I can't find anything in the rules that limits rim size, just that overall tire size is limited to 660 mm (26").
Old Jul 6, 2007 | 04:04 PM
Resident Monkey
Yeah, but i doubt they would use much bigger if they rules allowed
Old Jul 6, 2007 | 05:35 PM
mac11's Avatar
Rotary , eh?
I would bet they would run as large as they could get away with. The larger the rims are, the more brakes they can fit under there.
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
amshaw
RX-8 Multimedia/Photo Gallery
10
Aug 26, 2015 08:50 PM
cschoeps
Aug 6, 2015 12:44 PM
Brandonien
Jul 30, 2015 12:33 PM
