Engine Cooling fan remains on
Old Jun 26, 2007 | 09:14 PM
lilming's Avatar
Hi all,
sorry, am noob to the rx8. Got my 2007 6AT not too long ago. Just have this weird thing I wanna check out with the gurus here...
My engine's cooling fan occassionally doesn't shut off even after I turn the engine off and the key's out of the ignition. It remains on for like 5 to 10min and I'm not sure if it auto cuts off because by then I would put the key in, switch it on then off it again, after which the fan shuts off normally. Happens once ~15 to 20 times I turn off the engine.
Did a rough search and some people said it's normal enough, esp after u've driven the car hard (which I don't really....redline once every 2 days that's it)... just that i came across a couple of articles that mentioned that they had this problem before their engine died on them... so am a little worried.
Thanks again!
Old Jun 26, 2007 | 09:25 PM
dillsrotary's Avatar
jersey fresh
it's normal, if it's real hot out they'll stay on for about 5 to 10 mins when the car is off. dont' worry.
Old Jun 26, 2007 | 09:42 PM
lilming's Avatar
Thanks!!
Was just a little worried.
As a side point, if this occurs more frequently, would it be an indication of poor cooling? Cos I have only 1 oil filter in. Am considering installing an ATF cooler and CAI + Ram Air induction.
Thanks again!
Old Jun 26, 2007 | 10:03 PM
jersey fresh
the fans run do to engine temps (radiator) not the oil, but if the fans are running then the oil is mostly just as hot. I second oil cooler is always a good idea.
But remember this will happen on hot day, just because it happens more doesn't exactly mean you have poor cooling units, but i would upgrade to a second oil
Old Jun 27, 2007 | 10:44 AM
coupe07's Avatar
SC 300HP!!
Originally Posted by lilming
Thanks!!
Thanks again!
CAI + ram air???? How u gg to link it to ur air box?
1 oil filter is correct... if u have 2, something is wrong. Engine oil cooler u mean?? 6AT shld have 2....
Old Jun 27, 2007 | 11:37 AM
ngkenny's Avatar
stock standard
post *****
wa....very long nvr check ur post count...cheebei.....2954 already.....46 more u champion already. this time must give trophy.
i not far behind also.
+1 post
Old Jun 27, 2007 | 08:08 PM
lilming's Avatar
Yeah, my apologies. I'm talking abt engine oil cooler. PI 6AT only 1 right? I'm thinking of putting one more in with an ATF cooler as well. Do you mind PM-ing me what would the approximate charges be like plus labour at MG? SO I can budget when I can do it.
Abt the CAI...just something I read abt. Read that Racing Beat is good....not sure if it's recc by the guys here. Any ideas?
Thanks again!
Old Jun 27, 2007 | 08:22 PM
mkl22's Avatar
Thanks again!
6AT got 2 OIL COOLER la. read properly!!!
Old Jun 27, 2007 | 09:15 PM
lilming's Avatar
Whoops! My mistake. Been reading that PI's RX8 comes with only 1 oil cooler as opposed to MM. Guess that's for 4AT then. That's great then....one less thing to install!
Old Jun 27, 2007 | 10:01 PM
csl's Avatar
csl
There is a shop called Wangan in KL and sell RX8 after market aluminium radiator (about RM2.2k) and good coolant. He is a forumer here call wangan. If Singapore price is expensive, call pm him.
Old Jun 28, 2007 | 06:12 PM
sqflyer's Avatar
Heavy Machinery Operator
+1 post
Wei wei wei.. stop hijacking other people's thread lah...
The Racing Beat with Ram Air Duct is one of the best intake mods available for our 8s. I've personally reviewed it a long time ago and almost every 8 worth it's salt is running around with one, other than those FI'ed 8s that has their specific intakes.[/QUOTE]
+1 post too
Old Jun 28, 2007 | 07:57 PM
lilming's Avatar
+1 post too[/QUOTE]
It's ok...no prob! everyone can +1 post here...
Am quite keen on the RB mod. Will search for your review then. Hmm... guess I shouldn't ask for the approx price here right? heh
Think maybe mid to end july, drive down to MG to get it done since I clearing leave. If I wan to get it done plus install ATF cooler plus change ATF fluid, abt how long I gotta leave my car there? And must call them beforehand to indent or they usually carry ready stock? (sorry, maybe should ask Coupe07)
thanks!
Old Jun 28, 2007 | 08:09 PM
sqflyer's Avatar
I bought my RB Intake and Ram Air Duct direct from stateside for about S$1.2K. I'm sure coupe07 will be able to give you a better idea the lead time to order the parts, time required for installation and price. PM him if he doesn't post here.
vapor2
Nov 3, 2020 03:38 PM
rotorocks
47
May 11, 2016 03:23 PM
Nisaja
Aug 6, 2015 01:27 AM
Bamaham
Jul 23, 2015 08:08 AM
