Advan/Volk offsets
Old Jun 25, 2007 | 10:28 PM
arr ex eight's Avatar
Advan/Volk offsets
For those who have experience with Volk Ce28N and Advan RS, what offset and dimensions would give me an aggressive look with a good amount of concavity? I am looking for ce28n or rs in 19s.
I'm looking for a staggered setup. I cant find the answer to my questions through the search so hopefully someone can chime in. Thanks in advance guys.
Old Jun 25, 2007 | 11:05 PM
As close as you can get to stock. That's a 45 mm off set.
Old Jun 26, 2007 | 01:28 AM
really? i thought lower numbers (ie. +35, 30, 22, etc) tend to yield more agressive looks.
Old Jun 26, 2007 | 02:00 AM
NgoRX8's Avatar
oh boy.. way to steer him the wrong way.
lower numbers do make for more aggressive (i.e. moves further out)
what do you plan on staggering with? 8.5 and 9.5? here's the overall plan for most people regardless of wheel. (as long as you clear brakes)
+34 on front will fit fine with no rubbing and for the rear it's in the range of +40 unless you roll the fenders. rolling the rears will allow you go to lower up to about +34 as well.
also, rubbing depends on your tire size as well. a lot of us typically go 245/35/19 F and 275/30/19 R, but it does make the front wheel a little larger than the rear. be prepared to sacrafice a lil handling with this staggered set up.
most of the people i've seen here w/ ce28's have gone non-staggered and i believe 8.5 all around. it's your choice.
Old Jun 26, 2007 | 02:05 AM
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jun 26, 2007 | 02:20 AM
NgoRX8's Avatar
even better
http://www.rims-n-tires.com/rt_specs.jsp
Old Jun 26, 2007 | 02:24 AM
good job..
if only that link would end the stupid..
Old Mar 2, 2009 | 09:42 PM
arr ex eight: I think you should post pix of your advans in here.
hufflepuff
May 30, 2016 10:45 AM
Richard Paul
Aug 17, 2015 01:49 PM
R2D2X8
Aug 17, 2015 08:47 AM
jaehyun127
May 29, 2004 08:04 AM
