Bass controller for RF amp
Old Jun 23, 2007 | 06:31 PM
XLR83N's Avatar
Hello peoples,
Just wondering if anyone out there has installed a Rockford Fosgate amp to there bose system and had troubles with there bass controller. Mine doesnt work at all, and the gain on my amp is set quite high. Isnt that a bad thing?
Thanks in advance for your help
Old Jun 23, 2007 | 08:04 PM
Tigerfootball's Avatar
Clemson, NOT Auburn
need to know a few things first. what LOC did you use to connect the amp to your system and where did you tap in? and what does your amp sound like with the bass remote unplugged? maybe you have a bad connection or remote?
Old Jun 24, 2007 | 12:39 AM
XLR83N's Avatar
i havnt unpluged the remote, didnt think of that lol. i dont think that its the connection (hope not coz i cant be bothered to rewire a new one lol) because it is a 'click in' connector, but i dunno
i just used a converter that i found at all the audio shops here, nothing flash, tapped into the speakers just before it got to the bose amp
Old Jun 24, 2007 | 09:25 PM
tommy04rx8's Avatar
new guy for now
need to tap after the amp i think
Old Jun 25, 2007 | 04:14 AM
XLR83N's Avatar
i read that the signal is all wierd after the amp, and most people tap into it before the amp. can anyone confirm?
oh and i took my bass controller out and no difference, only when i plugged it back in again there seemed to be a pop in the sub and obviously the light turned back on (on the controller)
Old Jun 25, 2007 | 07:11 AM
paulmasoner's Avatar
Asshole for hire
you can tap in before or after the factory Bose amp. I personally am tapped in BEFORE, cause like you said, the Bose amp does some weird things... but its a LOT less powerfull than tapped in after
Old Jun 25, 2007 | 04:58 PM
XLR83N's Avatar
so i should try tappin in after?
also, what are the wire colours after the amp for the rear speakers?
Old Jun 26, 2007 | 07:43 PM
jstkilntim's Avatar
resU deretsigeR
Normally the only reason a remote bass controller will not work is a faulty plug or wiring. The potentiometer (****) almost never goes out. Take the **** out, hook it to the amp w/ a new cable to verify.
Old Jun 27, 2007 | 06:44 AM
XLR83N's Avatar
yep, the cable was the problem, argh gotta take it all out now to run a new one thru
pjwermuth
Sep 28, 2015 11:36 PM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
