Making the oil pressure gauge functional
Old Jun 19, 2007 | 06:49 AM
Delmeister's Avatar
The oil pressure gauge is fed a steady signal by a microcomputer that appears to be within the instrument cluster. If we can get access to the input of this gauge, we should be able to make it read actual oil pressure by exchanging the pressure transducer with a variable output device, and designing a signal conditioning circuit to interface the transducer signal to the gauge.
We need to know if the gauge inputs are accessible, and how the gauge responds to inputs over its whole range. We also need a source of pressure tranducers. Does anyone currently have their instrument cluster out that can take a look at getting some of this information?
Old Jun 19, 2007 | 07:05 AM
BoosTED's Avatar
I have been very close to buying a cluster to look into this.
https://www.rx8club.com/series-i-tech-garage-22/making-oil-pressure-gauge-into-true-gauge-8767/
Old Jun 19, 2007 | 07:44 AM
Delmeister's Avatar
Never saw that post by POOMan. If you do get that cluster, could you also look at the coolant temperature and tachometer gauges. It would be useful to hook in a beeper to immediately draw your attention to an overheated condition, and exceeding a pre-set speed (indirectly through the tach, unless the input to the speedometer is actually analog)
Old Jun 19, 2007 | 10:14 AM
SilverStreak's Avatar
I recall that over on Miata Net they had a way to make the oil pressure "dummy" gauge read actual pressures. I believe that it involved replacing the sensor on the engine only. Not sure if the same would work for the 8, never got around to doing it on my wife's Miata either. But if the sensor is the same, you may be able to find where to get it over there.
Old Jun 19, 2007 | 11:06 AM
Delmeister's Avatar
http://www.miata.net/garage/opg.html
This is probably what you mean. But in that case the replacement gauge must already have the capability of accepting the signal from the replacement sending unit.
Old Jun 19, 2007 | 01:03 PM
That is one of them, if you go into the garage there are actually a few more ranging from the NA models through the NBs. A bit more complicated than I remembered and some of the gauges would accept the signal but it was only relative because they weren't actually calibrated. Certainly it would be a lot more complicated in the 8
Old Sep 27, 2007 | 07:13 PM
w0rm's Avatar
PUSHER ROBOT
This seems like a worthwhile project. Was there ever any progress made here?
Old Oct 12, 2007 | 05:00 AM
Argento Otto's Avatar
bump for a good idea!
Old Oct 13, 2007 | 09:41 AM
tskeltonPGA's Avatar
no ****!
Old Oct 23, 2007 | 09:26 PM
Slick8's Avatar
1999-2005 Miata fix that works and turns the oil pressure gauge into a REAL gauge.
Website with the fix
http://www.mazda-speed.com/faq/opg/
Youtube that show that it works
www.youtube.com/watch?v=aTWvl2_5zoo
Old Oct 24, 2007 | 01:28 AM
The Miata's oil pressure guage is already a real/functioning gauge, though. The mod above just makes it more responsive.
Old Oct 24, 2007 | 01:57 AM
Spinning Sushi's Avatar
I <3 Sushi
This is something that I would love to do to my car... damn useless oil pressure gauge!
Old Oct 24, 2007 | 02:22 AM
MazdaManiac's Avatar
The oil pressure info is sent via CAN to the cluster.
The gauge is a surface mount, non-proportional electromagnetic indicator.
The only way to do this would be to gut that section of the cluster and mount a real, proportional driver and wire it to a linear sender.
Thanks but no thanks.
Old Oct 25, 2007 | 09:05 AM
chetrickerman's Avatar
so there is no hope for getting the gauge to work?
Old Oct 25, 2007 | 09:09 AM
Slick8's Avatar
Never say never
Old Oct 27, 2007 | 07:07 PM
Sabo's Avatar
Has anyone ever asked Mazda why they sold a car with an oil gauge that doesn't work? When I asked my dealership they told me it did work..... If enough ppl complain maybe they will do something, or at least give an answer.
Kinda of like my Ipod adapter won't work with XM Sat.... Mazda doesn't have a part, I can buy one for $200 though.
Old Oct 27, 2007 | 08:38 PM
lone_wolf025's Avatar
Future Rotary User
The theory behind dummy gauges is that its a selling point that they have them, but since its just a dummy gauge they don't have to worry about people bringing in the car because the oil pressure is a few ticks off from where it usually is. You would think that on a "flagship sports car" the gauges would be functional...but then again that would make sense and we can't have thinks making sense otherwise the whole system will collapse in on itself...
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
