Fuel flow during coasting? (scangauge)
Old Jun 16, 2007 | 05:15 PM
xr8ed's Avatar
Hello,
I just got my scangauge recently. While monitoring the fuel flow gauge, I noticed that the RX8 flows ~0.5GPH even while the engine is coasting down in a gear. I am amost certain that there should be 0 fuel injector pulsewidth during coasting, is there a reason the scan gauge reports fuel flow? Is this the nature of a rotary?
Old Jun 16, 2007 | 05:58 PM
RotorWheeee's Avatar
04 and still lovin it
This would be the nature of any fuel burning engine......No fuel , engine stops. You will have fuel flow at idle or at any time an engine is running
Old Jun 16, 2007 | 06:05 PM
mysql101's Avatar
while engine braking the engine doesn't need fuel to keep turning.
Old Jun 16, 2007 | 06:10 PM
rotarenvy's Avatar
most cars with an instantaneous fuel consumption value will read zero or no fuel while coasting down.
would the engine stop as it is being turned over by the wheels?
things change at low rpm when a stalling condition may exist but for coasting it seems like no fuel is required.
Old Jun 16, 2007 | 09:25 PM
xr8ed's Avatar
Any reason why the scan gauge does not read 0?
Old Jun 17, 2007 | 09:35 AM
NotAPreppie's Avatar
What am I doing here?
Calibration issue?
Old Jun 19, 2007 | 11:00 AM
zoom44's Avatar
becasue the injectors are still injecting
Old Jun 19, 2007 | 05:36 PM
midlife crisis's Avatar
Could it be a function of the oil injection keeping the rotors lubed?
Old Jun 19, 2007 | 05:59 PM
Originally Posted by xr8ed
Hello,
in gear it should or coasting is should read mpg. confused..
Old Jun 20, 2007 | 08:53 PM
xr8ed's Avatar
So are you saying our cars do not have Decel Fuel Cut Off?
Old Jul 6, 2007 | 02:06 PM
xr8ed's Avatar
Are you saying your car doesn't have Decel Fuel Cut? I'm pretty sure mine is supposed to have DFCO.... along with everyone elses except yours.
Old Jul 6, 2007 | 02:42 PM
two rotors's Avatar
The way the system is supposed to work during deceleration is fuel cut to both rotors when throttle valve is fully closed and fuel cut to one rotor when throttle valve is not fully closed.(Mazda Service Highlights,9999-95-102F-04,sect01-40-31).
Old Feb 10, 2008 | 07:16 PM
CnnmnSchnpps's Avatar
No means yes
FWIW, I just got a scangauge and mine reads 0.00GPH (gallons per hour) and 9999 MPG (infinity) when decelerating. Try setting the refresh rate to "fast"?
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
XianUnix
Sep 29, 2015 03:48 PM
DeltaJ802
Sep 29, 2015 01:20 PM
