Fiberglassed my trunk for cheap.
Old Jun 10, 2007 | 09:19 PM
evilmiata's Avatar
I was looking at my trunk one day and thought I could do something better. I had 2 10s behind the back seat and a battery relocated by the quarterpanel. I should be able to do better than that. Could I do better than the 4080 boxes? How about a rotor theme? (like that hasn't been done before) Nevertheless, I figured I could do something cool on the cheap.
First I cut out a MPF base panel and routed out a rotor-shaped speaker surround and flushmounted the sub. Built a frame and stretch polyester over it.
Throw some fiberglass resin on it....
Alright! This is going to be cool! Fits right into the quarterpanel. Only thing is that I need to move the battery and amp now. Well, I've got all this spare tire well room, so why not use it?
Now I just need to make one for the other side. But why should I get rid of that box? I just happen to have an extra set of 10s in the garage....
Oh yeah! Built a lightweight baffle!
You can see where the amp and the battery are going.
Throw some body filler on...
...Little bit of highbuild primer and wetsand...
This started out as on-the-cheap, so when I found out that VR paint would cost me $300/pint, I knew I had to find a better option. Maybe I'll have more money/time to mess with stuff later, but for now I'll settle for $2.99 worth of spraypaint.
Its not show quality, but "holy F" this thing drops! Should have been a factory option from the start. So, what did I learn? I can do a much better job stretching fabric and I need to learn how to spray highbuild better. Rattle cans will never match base/clear coats. But so what? I think its sweet, and plan to spray it again to match the grain on the factory plastic. Maybe a couple LEDs pointing down from the trunk.
So how much? Considering I already had the amp and speakers...
$40 1g resin
$20 4x8 MDF (good enough for 4 similar projects)
$10 4x8 hardboard
$40 10sqft fiberglass mat (enough for 8-10 of these enclosures)
$6 3sqft polyester fabric from Walmart
$20 quart slick sand (primer, used 1 pint)
$40 1g Rage Gold body filler (MUCH easier/lighter than Bondo, used >quart)
$2 wood glue
So a little under $200. Thats enough material for my car and my wife's truck (now in process). A few buddies/club members are already asking for help. This stuff isn't tough guys! Let's see some cool stuff. I'm definitely a fiberglass junkie now!
Old Jun 11, 2007 | 05:49 AM
whoneedspistons's Avatar
looks good man... how much does it all weigh?
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
GK1707
Sep 27, 2015 07:33 PM
mitchrx8
Sep 13, 2015 08:05 AM
