13b.20b.13B-MSP..HELP
Old Jun 8, 2007 | 07:27 PM
ohioka24de's Avatar
well im new to this forum. i have decided to buy a rx8 because my 240sx wont stop ******* me over good bye car.. BUT anyways im trying to figure this site out and what people do tothere cars but MAN its complicated... SO HELP ME i wanan find a motor i can start small with and work my way up. i have a t3/t4 some 550cc injectors a intercooler a wideband from innovative and a safc controller. SO for god sakes im USING SOME OF MY OLD PARTS..lol... i dont think i can boost the 13B-MSP because its too high compression and the motor is weak... the 13B(<$1500) will DROP right in so i might do that .. and a 20B(>$4000 ) alot of mods but worth it.. i wanna achieve maybe a 400-500hp car ... BUT if i can i wanna turbo the 13b-msp and run minor boost for fun.. so is it possible
Old Jun 8, 2007 | 07:30 PM
DarkBrew's Avatar
Extraordinary Engineering
Welcome to the forum
You need to find the search button on the command bar.
Old Jun 8, 2007 | 07:52 PM
MazdaManiac's Avatar
The MSP is stronger than the REW. It is the PCM that screws us up.
Old Jun 9, 2007 | 12:32 AM
dude, MSP is much stronger than REW.
good luck trying to *drop right in* a REW.
oh also, try to use the search function up top. Its very useful. and if you want to learn, thats where you should start.
Old Jun 9, 2007 | 01:10 AM
N rider89's Avatar
^NieL
if you can do everything custom for the 20b swap be looking at 10k+. if you get help look at 20k+
there is no just "drop it in"
Old Jun 9, 2007 | 01:50 AM
R Magic's Avatar
I'm gonna do my own custom 4 rotor, I'm thinking on using parts from the 13B-REW engine.. (Rotors, Housing, Etc.) Everybody is doing the regular 13B 3 rotor engine swap or the 20B 3 rotor. I wanna take it to the next level and have a 26B 4 rotor RX8.
Old Jun 9, 2007 | 05:35 AM
N rider89's Avatar
^NieL
Old Jun 9, 2007 | 09:06 AM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
Make sure you have a big fuel tank... maybe TWO big fuel tanks.
Old Jun 9, 2007 | 12:30 PM
Do it! Take pictures!
Old Jun 9, 2007 | 07:01 PM
Robbie's Avatar
There is absolutely no way you'll control an RX8 with an SAFC. If you think you're going to have a long lasting Renesis is with an Int-X or E-Manage Ultimate.
Old Jun 9, 2007 | 07:25 PM
R Magic's Avatar
The 4 rotor kit has the following:-
1:- Eccentric Shaft
2:- Front counter weight
3:- Rear counter weight
4:- 2 x Centre plates
5:- 2 x Stationary gears (modified)
6:- 2 x Stationary gear carriers
7:- 2 x Stationary gear external oiling mods
8:- Rear main nut
9:- 2 x eccentric shaft end caps
This kit is built with all new parts and also uses genuine Mazda parts, the kit is $9500.00 (NZ) This is a kit only and you will need an experienced engine builder to organize the rest of the parts and engineering and assemble of the 4 rotor engine. $9500 NZ = $6700 US ruffly, I'm guessing it's about a $10,000 engine minimum. $6500 for the KIWI kit, $3000 for the seals, $3000 for the housings and other stuff. Plus some of existed parts, I think $12-13k at most..
Old Jun 9, 2007 | 07:33 PM
N rider89's Avatar
^NieL
1:- Eccentric Shaft
8:- Rear main nut
This kit is built with all new parts and also uses genuine Mazda parts, the kit is $9500.00 (NZ) This is a kit only and you will need an experienced engine builder to organize the rest of the parts and engineering and assemble of the 4 rotor engine. $9500 NZ = $6700 US ruffly, I'm guessing it's about a $10,000 engine minimum. $6500 for the KIWI kit, $3000 for the seals, $3000 for the housings and other stuff. Plus some of existed parts I think $12-13k at most..
keep thinking that
Old Jun 9, 2007 | 07:52 PM
R Magic's Avatar
What's to think..? Price?! I'm sure it'll go up once I order parts, but it shouldn't be much higher. Only thing I'm thinking is why no one has done this before?!
Old Jun 10, 2007 | 12:23 AM
mostly because of $$$ issues.
I mean seriously, with enough funds .... I think anything is possible.
Old Jun 11, 2007 | 05:00 PM
Ice Cold RX8's Avatar
Has anyone ever delved into the idea of adding an additional Renesis rotor and housing to create a 3 rotor Renesis? What's involved beyond upgrading engine management, fuel, cooling & lubrication systems, new mounts and a new eccentric shaft? Is this possible?
Old Jun 11, 2007 | 05:16 PM
eviltwinkie's Avatar
Its LEGO housing time all over again!!
On a serious note to the OP...dude we are trying to be nice and not flame you as part of our new kinder and gentler hazing and initiation procedure....
However...please search and read up a bit more before reasking the question. People have come before you wanting the same things and stuff is out there waiting to be found.
As far as rotor grafting...yeah anything can be done with enough money...but just because something can be done does not mean that it should or it will be practical...You would be better served making a "Drop-In" kit for a 20B...But I think the ricans have already got that down to a science...
Old Jun 11, 2007 | 05:28 PM
YayAreaBruh21's Avatar
Its going to be way over the 13k mark. Look deep into it and check it out. Alot of guys in PR have done 3 rotor and its been pricey. You say you want "the next level" and expect to pay less? Your in for one rude awakening.
Old Jun 11, 2007 | 05:50 PM
fd3s_jerry's Avatar
if you want the "next level" you should have just bought an FD rx-7. they outperform the 8, and the e-shaft from the 8 is interchangeable, lighter, and stronger. plus the 7 is actually a performance car. the 8 is more of a fun to drive family car.
Old Jun 11, 2007 | 06:12 PM
a 4-rotor will be very long, with front drive accessories I don't see how it can fit in the existing engine opening between the steering rack and firewall/tunnel
the actual engine cost will be a drop in the bucket compared to everything else you'll need to shoehorn it in there and then make it work reliably ...
Old Jun 11, 2007 | 07:47 PM
chickenwafer's Avatar
Nope
if you think the Renesis is weaker than the REW then I would suggest to not do the work yourself
Old Jun 11, 2007 | 08:46 PM
fd3s_jerry's Avatar
bullshit. the "actual engine cost" of a 4 rotor engine is somewhere in the neighborhood of 12-15k. all said and done, having it in the car will be close to 20-25k. not just a "drop in the bucket."
Old Jun 11, 2007 | 08:59 PM
dillsrotary's Avatar
jersey fresh
jerry you show me where we can find a 4rotor for that price
edit: nevermind, you're just another fd fanbois
Old Jun 12, 2007 | 02:53 AM
dtorre's Avatar
Ultimate ****** Goderator
I was quoted 13K before shipping from Yashiro Iron Works last year when I was interested in a YR26B conversion .... 20k after shipping ><
Old Jun 12, 2007 | 11:13 AM
Socr8tes's Avatar
Sure, if you can deal with owning a 12-15 year-old used car and all the headaches that entails...
Old Jun 12, 2007 | 02:12 PM
fd3s_jerry's Avatar
wait until your car's 12 years old, I'd bet dollars to pesos that you sell the 8 after your first rebuild. and I haven't really had any trouble with the 7 at all, just preventive maintenance and being nice to it. it's still more fun to drive. I'm not hating on the 8, I like it for what it is, but I know what it's not, too. it's not really a performance vehicle, but a fun to drive family car. yeah, it handles, but it's still slow.
