8 not running smooth..
Old Jun 7, 2007 | 03:59 PM
nike178's Avatar
Hey guys.. i've been noticing that my rx8 is not smooth when u press on the gas or release it at any rpm... But once u keep ur foot constant there is no hesitation or "jerk" it accelerates fine. It's only if u get off the gas then accelerate again, the car will initially "jerk" then everything fine after that.. Is this normal? This happens at any RPM from low end to even more so high end. It even happens when i get off the gas also.. My FD didn't do this though.. What u guys think? It just seems like this car is very "jerky" to me.. I hope i explained this well..
FYI, I did plugs, wires, and ignition coils 5k miles ago...
Old Jun 7, 2007 | 05:06 PM
corners's Avatar
An RX ate my baby
Sounds like bad engine mounts.
Old Jun 7, 2007 | 06:09 PM
nike178's Avatar
i had a feeling it could be the engine mounts..
Old Jun 7, 2007 | 06:26 PM
Old Rotor's Avatar
There is a TSB for this problem, motor mounts. What is your miles and transmission type. Please give us all your info on car. Should be covered no charge.
Old Jun 7, 2007 | 11:30 PM
nike178's Avatar
I have a 2004 6spd with 40k miles... When i took the car in for the plugs, wires, and coils they ran the vin and he said all recalls were done on the car.. Not sure if the engine mounts were done..
Old Jun 8, 2007 | 03:31 PM
nike178's Avatar
The bulletin for bad motor mounts states that the problem occurs in 3rd gear at less than 3k rpm.. however, mine occurs at all rpm's in any gear.. I'm gonna make an appt w/ Mazda next week.. Hopefully its the motor mounts and nothing more..
Old Jun 9, 2007 | 12:11 AM
TSB is not recall.
Recall is *required*
TSB is something that they will do ONLY if
- the customer complains
- if the dealership cares about the customer and check it themselfs. (VERY DOUBTFUL)
Old Jun 9, 2007 | 12:50 PM
nike178's Avatar
I've also noticed that it gets considerably worse with the a/c.. Even my idle is more rough..
Old Jun 10, 2007 | 03:18 AM
Targatheory's Avatar
Do you mean like, as you step on the gas, regardless of gear or rpm, the increase in speed is initially a small jerk. As opposed to say any other car, it kinda "eases" into the speed when you apply gas.
I also notice this car doesn't coast too well. No matter what gear or rpm i'm at, when I let off the gas, the rpms drop quickly (making the car jerk the moment i let off the gpedal). Thus making me immediately add throttle, which makes the car "jerk" again. In other cars quickly letting go of the gas pedal would not do this. Because of this I tend to always feather the gas while daily driving, constantly, just to avoid this jerky car movement. It's quite annoying, and would love to know if it could be fixed.
Old Jun 10, 2007 | 05:36 AM
badmojo's Avatar
I noticed the jerky feeling after having bought a 2004 6MT in January. I had just attributed it to the rotary and endeavoured to be smoother on the gas pedal. At one point I went into the dealership with the motor mount TSB. They did a visual inspection of the mounts and a test drive, but were unable to replicate the problem according to the TSB. So they sent me on my way. Today, however, I was idling in neutral at a stoplight. I noticed the RPMs drop down around 500 and the engine almost stalled before the RPMs popped back up again. So I'm once again thinking the mounts might be bad.
Old Jun 10, 2007 | 08:34 PM
nike178's Avatar
Do bad motor mounts have anything to do with idle dropping like you say? Cause if so, then my car def has bad motor mounts.. Almost every time i'm at a red light, my idle drops to around 500 then catched itself also.. I know that bad motor mounts make the car idle rough but didnt know it can cause the idle to drop also..
Targatheory.. yes thats what i mean.. As soon as i step on the gas the car is jumpy or jerky for the initial time then its fine.. In contrast, when i drive my g-friend's TSX, once u step on the gas its smooth even initially there is no "jerk"
Old Jun 10, 2007 | 08:40 PM
Content's Avatar
maybe you have to clean your MAF sensor? Do you have a K&N air filter or any aftermarket intake?
Old Jun 10, 2007 | 09:16 PM
Wow, I thought thats just how the car was. Do any other members experience this?
Old Jun 10, 2007 | 09:38 PM
kersh4w's Avatar
Hit & Run Magnet
yeah, i do too. although its not very bad, or noticeable.
Old Jun 10, 2007 | 10:11 PM
if it shakes really bad when idle + A/C on, 99.9995% chance is that you have some bad mounts.
Please do not ask me how I know !
Old Jun 10, 2007 | 10:16 PM
that is how they test it...
get back to us after they test it..
beers :beers:
Old Jun 10, 2007 | 10:18 PM
that is another symptom..
get back to us after you have it tested.
Old Jun 10, 2007 | 11:26 PM
nike178's Avatar
My car is completely stock..
I am going to make an appt. Sat morning w/ Mazda. I hope its the motor mounts like you all are suggesting. Will keep u guys posted..
Old Jun 11, 2007 | 04:01 PM
nike178's Avatar
Just an update:
My car is actually going in for service on Wed. I printed out the TSB on the motor mounts and the one for the sqeeky breaks (yea i know, this one is gonna be hard to get them to fix.. but worth a try). I'm gonna give both reports to the tech so he knows i've done my research.. We'll see what happens..
Old Jun 13, 2007 | 04:09 PM
nike178's Avatar
ok so mazda just called me and said that they didnt find anything wrong with the car.. hmm.. what a suprise.. The advisor then told me they want to keep my car overnight and run more tests tomorrow.. How the hell can the tech not feel the jerk and hesitation when u press the gas??
Old Jun 13, 2007 | 04:54 PM
RX8Maine's Avatar
I am taking my car in next Monday for the exact same problem, and am afraid I will get the same runaround.
-Vibration at idle getting much worse recently
-Jerking so badly with throttle changes so badly that I can not use second gear in a parking lot at low speeds; the whole drivetrain just feels loose
-The jerking is present in all gears, but not quite as harsh. There is nothing magically different in 3rd gear below 3000 rpms
-My idle rpm's occasionally drop down to 600-700 then slowly recover. Someone on here theorized that the engive vibration can actually trigger the knock sensor, leading to timing retard and near stalls.
Old Jun 13, 2007 | 07:24 PM
RX927's Avatar
Embrace The Sparkles
nike178 which dealership in nj have you had this checked?
Old Jun 13, 2007 | 07:38 PM
they didn't do a test drive, just visual inspection or maybe they never go to it.
Old Jun 13, 2007 | 07:41 PM
nike178's Avatar
Its at Mazda in Ramsey.. When i first bought the car i took it to the dealer in Lodi but didn't like how there were too many young mechanics there.. Just looked like a bunch of kids working there.. I then took it to Ramsey for my last service and now for this one..
Old Jun 14, 2007 | 04:00 AM
209RedLine's Avatar
New To the family
i just pick up a 04 6mt with 40k .. 4 days ago .. every time i get of 1st gear to 2nd it has a jerky feel i try to drive b/w 3k to 5k rpm. is it b/c iam not taken it to higher rpms or from what i have been reading the motor mounts??? iam still under fac. war. if that makes a difference.. advice please. new to the family
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
