Tire Pressure Question
Old Jun 4, 2007 | 12:16 AM
OBTIQ's Avatar
>> Motion
Hey, I just wanted to know what level of psi should I have on my 235/40/18 tires... currently from the tire installer they are set at 40... and Im guessin thats way to high...
Old Jun 4, 2007 | 12:33 AM
i would start at 33 to 35 and go from there... size of tire does not matter contact patch does..
Old Jun 4, 2007 | 01:06 AM
NgoRX8's Avatar
yes, if it is for daily driving about 35 is the average.
otherwise:
decrease tire pressure = increase grip
increase tire pressure = decrease grip
up to certain degrees that is.
Old Jun 4, 2007 | 10:12 AM
CosmosMpower's Avatar
1935 lbs. FTW!
32 cold, I ran 35 cold for a while and noticed the middle was wearing a lot more than the edges even with aggressive camber and autocrossing on them.
Old Jun 4, 2007 | 12:18 PM
OBTIQ's Avatar
>> Motion
well im about to do a 5 hour drive, so I guess i'll set them at 34psi
Old Jun 4, 2007 | 12:54 PM
More_Revs's Avatar
I'm bone stock and I noticed the same thing. They were at 34psi early April, so probably gained a couple psi as it gets warm to about 36psi. the middle wear a lot more even before my track day. It's back to 32 now, and it ride so much better. Of course they were pretty worn to begin with, so off to my new tires...
Old Jun 4, 2007 | 08:02 PM
NoRotorNoMotor's Avatar
Mazda Only. 10+yrs
Weird. ... I've been running higher pressures (38 -40) and find the outer edges are more worn than the inside. (still have the stock Dunlops)
Old Jun 4, 2007 | 08:06 PM
longfury's Avatar
I have been running at 37psi on my OE Dunlops. Also the factory alignment. I have not had a problem yet.
Old Jun 4, 2007 | 09:19 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Kumho Ecsta SPT 225/45R18 at 35PSI.
Old Jun 5, 2007 | 04:12 AM
deamicls's Avatar
Bridgestones Potenza RE050A with 35 front and 34 rear. Works great. No abnormal wear on any corner.
Old Jun 5, 2007 | 09:32 AM
h-khunterkiller's Avatar
for hire
i believe your kumho can handle a litttle more im in the 40'S. look at the max tire pressure
drebbrnator
Dec 27, 2018 07:02 PM
olivierapex
RX-8 Racing
12
Sep 4, 2015 12:14 PM
GracefulShanks
Aug 18, 2015 11:40 AM
MolecularConcept
Jul 26, 2015 09:09 PM
