Help problems with intercepter N/A
Old May 30, 2007 | 12:13 PM
smrx8's Avatar
Not sure if its normal but at around 8500 rpm my ignitions drops.When they remove the unit the car runs fine all the way to 9000 rpm .the car runs perfect till 8500 and then that when they notice the dip on the map.
Old May 30, 2007 | 01:50 PM
MazsportScott's Avatar
Mazsport.net
Sounds as if there is a setting that is not correct. Have them call me @ 727-530-9960,Scott
Old May 30, 2007 | 02:09 PM
smrx8's Avatar
thanks so much , having the shop call you .
Old May 30, 2007 | 04:04 PM
Mazsport.net
I spoke with your tuner, he is sending over datalogs and will be performing some other tests.
Old May 30, 2007 | 04:28 PM
smrx8's Avatar
Wow im really really impressed with how fast you respond to problems even after i purchase the pruduct. A big thank you
Old Jun 4, 2007 | 02:01 PM
remliw's Avatar
Hi Scott,
I sent you the datalogs and other tests findings. I used the sales@mazsport.net email address. Let me know if you received the files.
One more time thanks for your support!
Old Jun 14, 2007 | 07:41 AM
remliw's Avatar
Thumbs up Moving forward!
Scott,
Base on your recomendations the ignition breakup is under control. We have not experience the breakup since we open the gap between the Pickup and the Wheel trigger. Now that we got this problem fixed, we are moving forward with the 75 shot of nitrous.
Once again thanks for your support!
Old Jun 28, 2007 | 04:03 PM
dynamho's Avatar
remliw, I deduce that you offer wideband tuning for rotary engines? Would you tell me where you're located in NJ?
Old Jun 29, 2007 | 09:17 AM
remliw's Avatar
Yes we do. I work for JPR Imports and we are located on
110 harmon drive
Suite 203
Blackwood, NJ 08012
If you need more info please give us a call (856-227-1808) and ask for James Phillip.
Later,
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
