LOTS of smoke coming on start up
Old May 28, 2007 | 11:55 AM
rotorious's Avatar
having a problem i cant figure out. whenever i start my car there is a lot of smoke coming out of the exhaust. it is a white smoke and only happens on cold startup. no check engine light on and the car isnt running an different. im in socal so its not to cold out here. anyone have any idea what it could be?
Old May 28, 2007 | 12:56 PM
Jax_RX8's Avatar
Got Another Rotary
Condensation/Water leftover in exhaust burning off as it warms up.
Old May 28, 2007 | 02:03 PM
Shifty Devil's Avatar
Worst case is a coolant leak into one of the chambers. When it is parked the coolant is still under pressure and is forced into the chamber. My old RX-3 developed a leak and while it was off coolant leaked into the chamber and when I started it it smoked like one of those insect fogger trucks for a few minutes until the coolant cleared out.
Old May 28, 2007 | 04:40 PM
staticlag's Avatar
The Professor
smell it. Is it oil ?
Old May 28, 2007 | 06:58 PM
Nemesis GP's Avatar
Hey Gents having problems with my cel-took it to private dealer and computer says bank 1 sensor 2 damaged-anyone knows which lambda sensor that is?
Old Jun 6, 2007 | 10:57 PM
rxman08's Avatar
it could be a condensation.. or a leaky valve seals.. White smoke is usually either coolant in the engine, or oil in the exhaust from a turbine seals..
Old Jun 6, 2007 | 11:19 PM
MazdaManiac's Avatar
Leaky valve seals?
Could just be a burned valve guide or bad cam timing.
He should check to see if his timing belt has slipped.
Old Jun 6, 2007 | 11:34 PM
Easy_E1's Avatar
Old Jun 7, 2007 | 12:34 AM
Might as well ignore this thread, he hasn't checked back since he started it.
Old Sep 8, 2010 | 07:16 PM
mark joy's Avatar
Question i dunno
hey that happened to me today!
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
RayBarron
Oct 19, 2015 08:08 PM
iSki123
Jul 27, 2015 12:41 PM
marc2820
Jul 26, 2015 10:47 PM
RX7.9
Jul 20, 2015 12:01 PM
