Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
HPDE in July
Old May 21, 2007 | 01:59 PM
avenger's Avatar
likes to do drawerings
HPDE in July
Just wondering if anyone else is planning on running with the Driver's Edge at MSR-Cressen in July? I'm pretty sure Twinkie is. Anyone else?
Old May 21, 2007 | 04:46 PM
eviltwinkie's Avatar
Heard nuthin but good things about the ranch...I'm soo there...
Old May 21, 2007 | 06:59 PM
BigRed's Avatar
w8nkel
after getting some new wheels i might not have the money.....as of yet
Old May 21, 2007 | 08:29 PM
Dude I run the stockers just fine...just get yourself a nice set of tires and you should be golden.
Old May 21, 2007 | 09:34 PM
BigRed's Avatar
w8nkel
i already ordered the wheels and im 16 so i dont have that much money...... i might just go on the new rims then with stock tires. i wont be driving that fast. i just have to come up with enough money for entry. will try hard though!
Old May 22, 2007 | 10:51 AM
avenger's Avatar
Screw the tires ... get brake pads first.
Old May 22, 2007 | 11:07 AM
Damn you and your logic!! I'll trump you and say...
Screw the pads and change the fluid first! Ha!
Old May 22, 2007 | 11:14 AM
j_tso's Avatar
I'll get the pump!
Old May 22, 2007 | 12:12 PM
avenger's Avatar
Heh ... if you're changing the fluids hope you change the lines first. Won't matter the if the fluid isn't boiling is your lines inflate like ballons. Trumped!
In all seriousness though you probably want to change the following ...
Brake lines to SS (do the clutch line too)
Brake fluid to something decent
Brake pads
Not that you can't have a good time without changing those things but in the Texas summer weather, the ambient temperatures won't allow everything to cool down significantly between sessions. You'll start to notice the brake feeling spongy towards the middle/end of the run days. Not that you can't compensate but it'll allow you to keep your pace up further along into the day. Same with stock pads ... they don't absorb the heat too well and you'll notice that you aren't getting the same braking grip as you were in the first couple of laps. Car will see significantly higher temps, might as well be prepared for it.
All of this will vary based on your experience level and the track but it's a good thing to do.
LB2739
Jul 9, 2019 02:25 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Danield97
Sep 30, 2015 05:59 PM
FERRET
West RX-8 Forum
Jul 22, 2015 02:25 AM
