Where to buy Thermo Wrap?
Old May 16, 2007 | 10:19 PM
R888's Avatar
WedsSport Member
Arrow Where to buy Thermo Wrap?
I can't find it except online...
Homedepot?
Canadian tire, NO!
Walmart, NO!
Where? :<
Old May 16, 2007 | 11:46 PM
R.P.M.'s Avatar
Rebuilds anyone?
You mean this kind of stuff? http://www.cryo2.com/products.asp?m=sp&pid=9
I have a couple rolls in stock and can get anything else made by them.
Old May 17, 2007 | 07:40 PM
R888's Avatar
WedsSport Member
Thanks RPM,
I need the ones that can wrap with the AC, can you help please?
Old May 17, 2007 | 07:44 PM
Wilson's Avatar
Peeping over the fence
Go to any air-conditioning supply house. You can get it in a roll of foam tape. Doesn't cost a lot.
Old May 29, 2007 | 11:43 AM
HarshJay's Avatar
Sweet I want to wrap my headers if it can actually drop engine bay temps by 50%, What size/length would I need for the 8?
Old May 29, 2007 | 01:00 PM
climacus's Avatar
You want to wrap your exhaust header? Do you realize how hot it gets? It glows red like a lump of coal on the dyno.
Old May 29, 2007 | 11:28 PM
R.P.M.'s Avatar
Rebuilds anyone?
Which would be a pretty good reason to heat wrap it LOL.
It would only glow if it were under some hard driving conditions, it doesn't normally glow, although they are quite warm under normal driving conditions....waaay too hot to touch.
I've wrapped 13B N/A headers with the DEI wrap before and after a nice hard drive down the road and back I could still put my hand on the header without burning it.
That stuff works great!
Old May 29, 2007 | 11:29 PM
HarshJay's Avatar
abosolutely, check out the link, that's what they do.. direct the heat through the exhaust and away from the engine bay.
Old Jun 3, 2007 | 05:33 PM
Willicuddy's Avatar
Header wrap is excellent at lowering engine bay temps, but if you get any water on the headers (from the road or from washing the engine bay) the exhaust manifold will rust and eventually crack.
just my 2 cents.
Old Jun 3, 2007 | 07:25 PM
R.P.M.'s Avatar
Rebuilds anyone?
True, if the engine is not warm or up to temp, the header wrap will trap the moisture in it and make the header rust.
But if it the engine has been running for a while and the exhaust is nice and warm, the moisture will evaporate and not cause as much rust.....it will still cause some rust but not as much as just letting the water sit there. Know what I mean?
Old Jun 3, 2007 | 08:04 PM
Willicuddy's Avatar
I agree with you.
The best thing to do, if you had the time/money, would be to ceramic coat the exhaust manifold on the inside and outside. Only problem is that it is pretty expensive and your car would have some downtime.
Old Jun 3, 2007 | 09:12 PM
R.P.M.'s Avatar
Rebuilds anyone?
We actually offer ceramic coating and to have an older 13B header coated on the outside would be around $150. We use a Satin Black coating thats good for 1500 degrees F.
Mind you, an RX-8 manifold/header is a bit larger than the older 13B's so it'll probably cost a bit more. And yes.....downtime does suck
But whats even better is that we have an RX-8 stock manifold here we could get coated and just swap it for yours as a core, then the only real downtime is swapping manifolds.
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
Tros
Sep 16, 2015 08:53 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
