Homelink reset
Old May 16, 2007 | 03:29 PM
AJRX8's Avatar
04 RX8 owner
Homelink reset
Hello all. I recently replaced my home garage door opener, but I can't seem to get the Homelink mirror in my Eight to "memorize" the new garage door remote's signal. I followed the directions in the Mazda owner's manual but no matter how many times I run though the procedure I can't get any results. Is it necessary to disconnect the car battery to reset this thing? Has anybody else had the same problem? I haven't been able to find an answer anywhere... help!
Old May 16, 2007 | 03:39 PM
DarkBrew's Avatar
Extraordinary Engineering
My homelink wouldn't learn the remote so I gave up and had the garage door opener learn the homelink signal. (second procedure in the manual)
Old May 17, 2007 | 10:26 AM
fullsmoke's Avatar
Anatomy of a corner...
Could your opener be a "rolling" code type? If so, you have to use the physical garage door opener to program your Homelink.
Lucky you though, my Homelink only works when I'm INSIDE my gated community--it won't let me in from the outside... Wierd.
FS
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
cliffkemp
Dec 24, 2024 10:48 AM
OnebaddRx8
Aug 25, 2019 11:34 PM
fistofmeat
Oct 7, 2016 12:15 PM
vapor2
Jul 9, 2016 07:35 AM
