Carbing Rear Lower Arm?
Old May 16, 2007 | 03:03 PM
Derex'8's Avatar
ReDuX
Finished installing my rear carbing lower arm and have a question, as you can see from the picture it is right up against the exhaust..I plan to get my exhaust hangers shortened to fix this problem...
For the time being, until I get around to adj my exhaust hangers, do you all foresee any huge problem I might run into?
The paint as you can see is already melting away on the bar...From what I hear the bar is indeed steel...
Old May 16, 2007 | 03:23 PM
BoosTED's Avatar
Wow that must be a 3 inch pipe you have going for the exhaust.
Another option is putting a spacer under each side of the bar but I see there isn't a whole lot of clearance between the bar and the ground.
It is lined up between the tires so as long as a person doesn't drive over the top of something it should be fine.
Old May 16, 2007 | 03:24 PM
BoosTED's Avatar
Did you notice any improvement since you installed it?
Traction?
Old May 16, 2007 | 03:35 PM
Derex'8's Avatar
ReDuX
Yeah the exhaust is a 3"...Yeah I've felt a definate change...it's a bit to stiff out back for me now, so going to soften my rear shocks and bump my front PT bar down a notch...
Old May 16, 2007 | 03:41 PM
chrism's Avatar
Misfit Moderator TnC
i have had mine on for a few months now and havent had any issues....
Old May 16, 2007 | 03:42 PM
scsi's Avatar
maybe you can use exhaust wrap around that area till you can have the hangers shortened.
im sure you get a nice rattle while you're driving
Old May 16, 2007 | 03:44 PM
NgoRX8's Avatar
yea 3" exhaust definitely isn't going to work unless to do some altering. you're going to rattle
Old May 16, 2007 | 03:49 PM
Derex'8's Avatar
ReDuX
Surprisingly I have no exhaust rattle @ all right now reason probably being the exhaust & bar are so damn snugged together my bar is going to be ruined by the time I get my exhaust hangers fixed
BTW if planning to install this on your own you are definately going to need @ least 2 ppl minimum
Old May 16, 2007 | 03:52 PM
BoosTED's Avatar
Why is two people necessary?
Old May 16, 2007 | 03:59 PM
Derex'8's Avatar
ReDuX
maybe it's just me & noobishness but anyway I had to have someone hold & align my trailing arm while I aligned the carbing arm and put the bolt through...I wasted a hour of my time attempting this by myself
Old May 16, 2007 | 04:14 PM
Derex'8's Avatar
ReDuX
And not to mention how tight of a fit it is once you get one side of the bar hooked up I beleive install will be much smoother for ppl running stock height or a very conservative drop and ppl that have a stock exhaust or an exhaust thats modified to sit a bit higher up
Old May 16, 2007 | 04:19 PM
BoosTED's Avatar
Yeah I see your point.
Would it be easier if the shocks and springs were already out?
Old May 16, 2007 | 04:24 PM
take the wheels off and undo the shocks from the lower mount makes it a 1-man job because it removes all the pre-loading, I had a sumbich of a time when I didn't do it that way the first time, no problem the 2nd time doing it the way I described it
mine is up against my 3" exhaust too, it didn't have to be if I wanted to modify the pipe routing, just happened to line up exactly with the lowest point in the exhaust
Old May 16, 2007 | 04:29 PM
Derex'8's Avatar
ReDuX
^^+99 will definately try this next time
Thanks, its good to know I'm not the only one w/the bar up against the exhaust
Old May 17, 2007 | 03:44 AM
StuttgartRX8's Avatar
Nurburgring Camera Whore
Thanks for the tip I'm waiting for mine to get here from the states.
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
tgaffner
Sep 7, 2015 08:49 PM
PTQLam
Sep 5, 2015 01:14 PM
