brake rotor help
Old May 13, 2007 | 11:37 PM
brake rotor help
ok,
i have painted the calipers, changed the lines... used an impact driver to get the screws out of the rotors...
but cant get the rotors off... am i missing something? or do you really have to beat the f out of them?????
Old May 14, 2007 | 01:07 AM
Phantom Menace's Avatar
II SOCIETY
Originally Posted by swoope
ok,
Swoope,
I'm not sure about the 8, but I took the rotors off of my Z the other weekend (to install longer lugs & spacers) and after you take the caliper off, there should be a single screw on each rotor. Take that off and just whack the rotors from the inside out with a, rather, larger rubber mallet. They should come out.
Old Jun 22, 2007 | 08:47 AM
Apostle's Avatar
Cupcake Master
At least your were set in there. Took my tire off today to paint the rotors, the screws fell out.
Old Jun 22, 2007 | 09:04 AM
mysql101's Avatar
the screws are useless. they're temporary. you don't need them, as the nuts holding on the wheel will also hold the rotors in place.
my rotors were also a pain in the *** to take off. Almost gave up... we ended up taking a nice block of wood, putting it against various parts of the outer rotor, and then beating it with a mallet. The rotor will eventually come off. Also I sprayed PB Lube all over.
hufflepuff
May 30, 2016 10:45 AM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
D13
Oct 1, 2015 07:55 AM
