View Full Version : R6's in BS
ndtechie09
05-13-2007, 01:45 AM
Running in B Stock currently with no mods except for front pads and the upcoming Konis or Bilstein's how would Hoosier R6's be on stock rims compared to say the A6 or 710's for AutoX?
-Brett
B1mmer
05-13-2007, 07:50 AM
-Brett
It all depends on how warm it is out. If it's dead of summer in Texas, then R6's only have a slight disadvantage to an A6 or V710. In some cases, they could be an advantage if overheating occurs mid-way through a run.
In any weather other than above, they are a disadvantage. How much so depends upon how cold it gets. - AB
TeamRX8
05-13-2007, 09:36 AM
use 225's rather than 245s
Cito
05-13-2007, 10:02 AM
I think you mean 285's, right? (meant in sarcasm)
Unless you are getting the tires free or relatively cheap used, the Kumhos are the way to go, as are the Koni's.
From,
The guy with Hoosiers and Tokicos....
ULLLOSE
05-13-2007, 10:36 AM
Even the fast road racers are on A6's.
More_Revs
05-13-2007, 10:45 AM
Care to explain? I always thought, and told, to stuff the widest tire you can. Is it because of the tire section/thread width vs. the 8" wheel width?
mwood
05-13-2007, 12:35 PM
I believe baggy was obliquely making the point that you'll never get the R6 into it's intended temp operating range in autocross, so if you ran a narrower section at least you might get a more heat/a little closer ;)
PoLaK
05-13-2007, 02:07 PM
Yup i've heard that theory on the r6 before, although i don't know if that trade off is worth it especially on shorter courses with more focus on overall grip.
