checking oil when engine is cold...
Old May 11, 2007 | 11:08 AM
delhi's Avatar
Grand Chancellor
Is it accurate to check the engine oil when the engine is cold? as in not warmed up at all.
Old May 11, 2007 | 11:23 AM
Go48's Avatar
No significant difference. Do a test if you want to confirm. Check it before you drive off the first time for the day. Then after it has warmed up and the car sits for 5 minutes or so, check it again.
Old May 11, 2007 | 02:06 PM
delhi's Avatar
Grand Chancellor
thanks. It's just that the bloody dipstick is located in such a lousy spot I keep getting small burns from the hot pipes and metals around it. And my hands aren't even that big!
Old May 11, 2007 | 03:49 PM
Nemesis8's Avatar
Bigus Rotus
Mechanics gloves are your friends
Old May 16, 2007 | 08:00 PM
MP3Guy's Avatar
I wonder why Mazda recommends checking the oil on a warm engine that has been sitting for a few minutes. The "old school" logic is to check it dead cold to get the most accurate reading, and it's not as if the oil has to drain down from a valvetrain or anything.
Old May 17, 2007 | 03:09 PM
Marx8nka's Avatar
I have problems with the plastic tube coming out together with the dipstick if I'm trying to check the oils when engine cold... when warm the dipstick comes out nicely without the plastic tube...
Old May 17, 2007 | 08:41 PM
R-RevX's Avatar
Closer than it appears
I keep a pair of in my glove box, that's what it's there for.
Old May 17, 2007 | 08:52 PM
lone_wolf025's Avatar
Future Rotary User
Aww but the burns add character!
Old May 17, 2007 | 09:06 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep............suck it up and deal with it. Somewhat kidding! You know what's hot.........don't touch it and you won't get burned! I do have fairly large hands, ya just have to be careful. You can check it cold though!
Old May 17, 2007 | 09:11 PM
R-RevX's Avatar
LOL.. But I already got my fair share working on Uncle Sam's diesels.
Old May 17, 2007 | 09:45 PM
MazdaManiac's Avatar
You check the level when it is hot because a significant change happens as the coolers pump up.
There is a 1/4" difference on my level between cold and hot.
Besides - it isn't important how much oil you have in the engine when it is cold.
Old May 17, 2007 | 10:19 PM
Mazurfer's Avatar
True, but 1/4" isn't gonna smoke the car. Never checking it either hot or cold and being three or more quarts down is another story.
Old May 18, 2007 | 12:18 AM
True.
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
Sifu
Aug 30, 2015 10:51 PM
vssystemluba
Jul 19, 2015 04:16 PM
